Old 04-25-2019, 06:11 PM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
FS: Custom Switch Inserts w/ Illuminated Switches
UPDATE! I now take orders through my new webpage
https://www.seriesblueadventures.com...-panel-insert/
I make these myself, and I've sold over 80 so far, with no complaints! It's a plastic chassis with four, or six ON/OFF, SPST toggle switches. They have a red status LED on the tip, and are rated for 12V @ 30A. I make inserts in sizes to fit both push start and NON push start vehicles.
People have used this to control everything from Pedal Dance, to Radiator Fans, to Dashcams, to Radar Detectors, to Trailer Harnesses, to Driving Lights, to Underglow, to Air Compressors, to Active Exhaust, to Subwoofers, to Air Horns, etc...
This is designed to slot into the useless cubby hole in the lower dash. All you need to do is wire it up however you want for whatever accessories you have, and insert it into the cubby hole. You'll have to drill/cut out the back of the cubby to run wires, and I recommend a dab of glue in the long run once you finalize the wiring. A new trim piece is less than $5 at the dealership if this worries you.
PUSH START MODELS (smaller cubby)
$40 - Blank (cut your own holes)
$70 - 4 Switch
KEY START MODELS (larger cubby)
$70 - Blank (cut your own holes)
$100 - 4 Switch
$120 - 6 Switch
Shipping is $8/$10 anywhere in the continental US for the small/large panels. $14 international shipping.
PM me if you're interested!
Some Facebook-hosted photos. Let me know if they stop working:
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-03-2019, 02:49 PM   #2
Mdulin
Drives: Scion Frs
How would you program it for pedal dance?
Mdulin is offline   Reply With Quote
Old 05-03-2019, 09:03 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
you would need to set up an arduino to do that, and the switch would just be one of the inputs.
Old 05-23-2019, 09:40 PM   #4
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
$35 - Blank (cut your own holes)
$50 - 4 Switch
$65 - Blank (cut your own holes)
$75 - 4 Switch
$95 - 6 Switch
Interested, also where’d you get that alcantara cover to clean up that area?
Howaitoguru is offline   Reply With Quote
Old 05-23-2019, 09:52 PM   #5
Stang70Fastback
A.K.A. Starlord
I had it wrapped by Sweidit.
Old 06-14-2019, 11:25 PM   #6
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
I sent you an email!
SkyeHack is offline   Reply With Quote
Old 06-21-2019, 06:32 PM   #7
pauletello
pauletello's Avatar
Do you have blue colored LED ones by any chance?
pauletello is offline   Reply With Quote
Finished My Toggle Switches and Custom Wiring Stang70Fastback Electronics | Audio | NAV | Infotainment 10 08-26-2019 04:15 PM
[PLEASE DELETE] Stang70Fastback Audio/Visual, Electronics, Infotainment, NAV 5 12-20-2018 12:15 PM
Custom Sheepskin Seat Inserts Llilith BRZ First-Gen (2012+) — General Topics 18 01-24-2015 06:27 PM
Custom USB Cover Switch Chad86 Scion FR-S / Toyota 86 GT86 General Forum 14 01-12-2015 07:08 PM
Zeta Products Custom Console Inserts zetaproducts.net Interior Parts (Incl. Lighting) 28 06-14-2013 10:28 AM
