Old 05-15-2019, 10:51 AM   #29
Racecomp Engineering
Originally Posted by smg1138 View Post
@Racecomp Engineering How does ride height affect comfort? Like the lower you go on T2's does the ride quality become more harsh? I currently have mine about 45mm lower than stock and was thinking about raising it back up some.
The T2s do have a lot of compression travel, but lower ride heights will sacrifice that and will impact ride quality. IMO 45mm is too low and you might get both better ride and handling if you raise it up to say 30mm lower than stock. A little bit of rake (slightly higher rear than front) can benefit some applications as well.
- Andrew
smg1138 (05-15-2019)
Old 05-15-2019, 12:26 PM   #30
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Depends on how big the bump stop is and how far into it you already are.
ineedyourdiddly
Old 05-17-2019, 01:45 PM   #31
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
After installing the shorter end links, my sway bar is no longer hitting the control arm. No more clunking on low speed bumps.
C4RBON is offline   Reply With Quote
The Following User Says Thank You to C4RBON For This Useful Post:
Racecomp Engineering (05-17-2019)
Old 05-28-2019, 01:02 AM   #32
2Wavy
Drives: 2016 BRZ
I finally got around to buying these and getting them put on the car. The car is lowered an inch from stock, and the damper settings are set to the recommended settings from the install guide. I can honestly say the ride quality isn't anywhere near as harsh as I had expected. You definitely feel little bumps and any waviness in roads more, but they never feel harsh. On bigger potholes it feels like the T2s actually soak them up better than stock. I also had a friend with a 2015 WRX ride along and he said the ride quality doesn't feel any worse than the stock suspension on his car. Overall, definitely a daily driveable setup as long as you're not driving on insanely bad roads. The car does also feel more responsive in the corners and definitely more confidence inspiring when I'm pushing it hard in the twisties, but I'll wait to do an autocross before I make any further conclusions about handling.
2Wavy is offline   Reply With Quote
The Following 3 Users Say Thank You to 2Wavy For This Useful Post:
DarkSunrise (05-28-2019), Racecomp Engineering (05-28-2019), Tristor (05-29-2019)
Old 08-10-2022, 03:03 PM   #33
Tokay444
Sorry to revive an old thread, but what endlinks did you go with, and are you running OEM LCAs?
Old 08-15-2022, 12:57 PM   #34
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I'm actually also interested. I'm currently running the Perrin non-adjustable 'long' front endlinks with their 19mm bar and figured it might need shorter ones when moving to the T2's.
cmiovino is offline   Reply With Quote
Old 08-15-2022, 01:55 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Those Perrin front end links don’t work well. I had to bin a set. They also hit the inside of the body a lot. I think I have the 180mm white lines now and they don’t contact anything.
Old 08-15-2022, 03:31 PM   #36
strat61caster
Yeah I've got the Perrins in the rear, the seem really sturdy and quiet, if they last a long time they will be worth it. However they are not ideal geometry or easy to adjust. Good sporty street parts, not sure if ideal comp autox/track parts.
The whiteline are decent, but I had the nuts loosen over time, not sure how to prevent that, locktite maybe. Megans were in the same boat, they seem slightly less durable on the ball joints, but it's not the end of the world.
ineedyourdiddly
Old 08-15-2022, 04:36 PM   #37
I've been working on some endlinks.
We want something that can handle some weather and rod ends that actually last. Wasn't 100% happy with the first test set but they were almost there. I have a new revision on my car now.
Trying to make them easy to install, quiet, and strong. Good quality hardware, too. And of course proper lengths for our RCE coilovers and others.
No ETA yet, we've got a lot of projects at the moment. Still sorting a few details.
- Andrew
nathand (08-21-2022), Tokay444 (08-16-2022)
Old 08-15-2022, 05:23 PM   #38
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
- Andrew
Flanged metal locknuts for the end links please.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Racecomp Engineering (08-15-2022), strat61caster (08-15-2022)
Old 08-15-2022, 05:58 PM   #39
Indeed, that's important.
I have been using loctite on flanged nuts for the 2nd iteration...trying to figure out what makes sense for most people. For my use case, I've been swapping suspensions very frequently so a nut with a nylon insert isn't ideal.
- Andrew
NoHaveMSG (08-15-2022)
Old 08-16-2022, 01:37 AM   #40
marco_mc22
Drives: Toyota 86
- Andrew
The ideal are nord lock washers with standard or flanged nuts, they’re used in every application where bolts or nuts coming lose is a concern.
marco_mc22 is offline   Reply With Quote
Old 08-16-2022, 08:45 AM   #41
Nord lock washers are cool, however there is some concern (even if it's silly) about the serrations damaging the paint on the sway bar. Not important to most people I'm sure, but someone will be upset. I may still try them.
- Andrew
Old 08-16-2022, 11:57 AM   #42
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
- Andrew
Disc-lock makes a similar style ramping washer that doesn't have as aggressive external serrations. I buy a couple sizes of their lock nut, we like them since their lock nuts have smooth flanges and don't tear parts up.
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
Turbo 86 drivability tune issues 504 Software Tuning 3 08-23-2017 10:21 PM
e85 drivability questions Lantana frs Engine, Exhaust, Transmission 1 02-18-2017 01:43 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
Skunk2 Pro-C Coilovers - Daily Drivability 86Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-27-2016 01:03 AM
