#8373 | |
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
#8374 | |
| The Following User Says Thank You to jflogerzi For This Useful Post: | bfrank1972 (05-11-2019) |
#8375 | |
Drives: Boosted Toyobaru
#8376 | |
Drives: 2017 toyota 86
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | JDM_Import (05-12-2019) |
#8377 |
Drives: '13 SWP GT86
What is this? An intake temp sensor? It's something aftermarket anyway.. I bought my 210 used, but freshly rebuilt. But the stock plate that only housed the stock MAP sensor also came with the unit, but this was the installed one.
![]() If it is an IAT sensor, how do I splice it/connect it to the harness/ECU so Ecutek can read it?
IG @squareddesign
http://www.squareddesign.se |
#8378 | |
#8379 |
Drives: 2015 Firestorm 08/05/15
Good deal, the low end and mid range pull is stellar, I smoked many turbo setups 1 2 3 gear pulls. 4 the gear turbos start coming on strong, enjoy your set up partner.
#8380 |
Drives: UK GT86
It is, take 2 wires from the MAF. I can't remember off hand but the wiring diagram might help.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | sqd (05-16-2019) |
#8381 | |
Because I know you know a lot about the car/Sprintex/Ecutek and tuning etc. Exactly where I am at right now with my own build ![]() Gotta find out which those wires are.. Also, when hooking up a wideband O2 so Ecutek can read it, and replacing the secondary O2, am I thinking right that: - Wideband O2 harness to gauge (I have a AEM X-series gauge with the included Bosch LSU 4.9 sensor) - And from the gauge I connect the gauge harness signal cable to the blue one from the stock O2 I know, not really relevant to the thread but taking the opportunity here ![]()
IG @squareddesign
#8382 | |
Drives: UK GT86
They are 2 at one end of the MAF, 3 used for airflow, 2 for IAT. Just cut and reroute the IAT ones. I did mine with a connector so could be switched back if ever required.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | sqd (05-17-2019) |
#8383 |
Drives: 2k16 frs
Hi guys, I am looking for 72.5mm Pulley, does anybody has it? shipped to 92336.
Also, is it ok to have 72.5mm pulley on 210 sprintex with e85 flex fuel kit with stock injectors and fuel pump?. I have read before that it is safe to do so? Just want to confirm before I proceed. Thanks! |
#8384 | |
Drives: brz 2017 hksv2
yes for wideband, old bue is for output signal from gauge, white is for. reference it helped me connecting also the reference to the same ground as the aem gauge (black wire from gauge) for IAT it s the 2 wire left, when looking at the maf frontly, with the cables in opposite direction than you |
| The Following User Says Thank You to tomm.brz For This Useful Post: | sqd (05-18-2019) |
#8385 | |
#8386 | |
Drives: 2013 Subaru BRZ Limited (Black)
| The Following User Says Thank You to ajcarson11 For This Useful Post: | jflogerzi (05-19-2019) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
