Old 05-14-2019, 09:29 PM   #15
redlined600
redlined600's Avatar
Drives: Fr-s
Do you have a spoiler? I found that makes a difference in balance, albeit small.
redlined600 is offline   Reply With Quote
Old 05-14-2019, 10:24 PM   #16
i8ur911
Drives: 17 BRZ Series.Yellow
Just the stock spoiler (17 Series Yellow)
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 05-15-2019, 12:05 AM   #17
Butterballz
Drives: Black FRS
I have the front splitter with race upgrade, endplates, dive planes, and aggressive diffuser and I definitely notice a difference at 40mph+. The car feels more planted, especially when turning in. I can enter long sweeping turns faster with more confidence.
I had all but the dive planes off when I was installing some stuff on the car and drove it like that for a few weeks. After I installed the aero back, there was a difference when driving. Is it a huge difference? No, but it's noticeable. Will it make you faster? Probably not unless you're already driving the car to the limits. I admit that I a part of the reason I got it was for looks as well lol.
Butterballz is offline   Reply With Quote
The Following User Says Thank You to Butterballz For This Useful Post:
i8ur911 (05-15-2019)
Old 05-15-2019, 12:40 AM   #18
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by i8ur911 View Post
What are people running for aero?
I ask because I recently picked up a used Verus non aggressive rear diffuser and have been considering adding a few other pieces as well (Verus side splitters, a front lip and there JDM underbody panels).
What are you running and did you notice much of a difference?
For aero drag reduction. You have several options that do add up and also add downforce while reducing drag which is hard to come by. Starting front to back,
Velox wheel deflector, front aero fender fin, trd front/rear aero turbulator, trd underpanels, velox transmission tunnel cover, side skirts, velox rear diff cover, velox rear diffuser, trd aero stabilizing trunk cover, OEM spoiler.
Most front lips add a little drag but a ton of downforce, depends on the design, if made to be an air dam it may be able to reduce drag. Also lowering the car as much as possible reduces drag as well.
Drag is something you only notice at higher speeds. When speed doubles drag forces quadruple. As you get closer to triple digit speeds you will notice the car has an easier time continuing to pull then before.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 05-21-2019, 09:26 AM   #19
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Food for thought from an internet track rat rando: I had bought my apr gt250 carbon wing used off of the forum here. The riv-nuts that held the passenger end plate on were loose. Multiple attempts to rescue them with epoxy failed. One of the endplates seen in the picture came off on track running full tilt-boogie this past weekend.
I didn't notice until I got back to the paddock and some said "hey your wing broke!"
CFD would presumably show data and turbulent crazy squiggles showing/saying it made an objective difference! Oh no! Did I feel it? Nope. AIM data didnt show any indicators that I had to adjust driving. No impact to corner exit speed of the two high speed sweepers on the track I was driving. So I removed the other endplates for balance, and drove the snot out of the car the next day.
If I could feel a difference, it was tiny. The back end was a bit looser when the chassis was at full load. It wiggled its hips a bit more under heavy braking. BUT! It was hotter the second day. It rained between days- track had less rubber down. Maybe I was running less fuel the second day...the tires (maxxis rc1) had 5 more heat cycles...So many variables that the differneces made by the loss of endplates- a "big aero control" surface are lost in the noise.
TLDR; catastrophic wing end failure jettisond a 1 sq ft end plate at speed on track, experieneced driver didnt notice, lap times didnt change.
Joesurf79 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joesurf79 For This Useful Post:
i8ur911 (05-25-2019), Rickyyp (05-23-2019)
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 574 09-15-2019 10:10 AM
(CA) Verus aggresive rear diffuser TRDGriffon Exterior Parts (Aero, Lighting, Etc.) 2 06-21-2019 09:15 PM
Rear "carbon fiber" oem diffuser removal ReaperBRZ DIY (Do-It-Yourself) Guides 1 08-12-2016 02:26 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
Rear Bumper "diffuser" Removal sw20kosh DIY (Do-It-Yourself) Guides 6 07-31-2013 03:24 PM
