Old 05-12-2019, 10:42 PM   #99
Originally Posted by Adam_L View Post
So the higher the compression ratio, the greater the effect down shifting becomes ? I never knew that, if that's indeed true.
I downshift, it just depends on the situation, but usually it's one gear at a time 6th to 5th , or 5th to 4th , 4th to 3rd. Sometimes I'll go 4th to 2nd gear, if I go from 40 mph…. down to 20mph fast ( brake, or engine braking + downshift). I'll say in the last few years, I've been doing more braking… then downshifting ( I'd rather replace brake pads, then to go thru a clutch faster) … but it depends on the situation.
I do believe so.
And ….
Old 05-12-2019, 10:46 PM   #100
OK, I'll chime in with a serious observation.
It took me a while to get used to the relatively high release point of the clutch. The MX5 that I came out of had a real low release point.
soundman98 (05-12-2019)
Old 05-12-2019, 10:50 PM   #101
Originally Posted by vladniko86 View Post
It smelling like gas when I start it and throwing codes at me for cat efficiency below threshold
That ain't right, I suggest you get your car fixed.
Old 05-12-2019, 10:51 PM   #102
vladniko86
vladniko86's Avatar
Drives: FRS
Yeah I'll fix it later by throwing in some uel non catted headers and a tune but that's expensive and I'd like to do it all at once. Don't have the money right now
vladniko86 is offline   Reply With Quote
The Following 2 Users Say Thank You to vladniko86 For This Useful Post:
humfrz (05-12-2019), p1l0t (05-12-2019)
Old 05-13-2019, 12:04 AM   #103
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Been missing my driver's side marker light for a long time. Sometimes someone at work will ask what the hole in my fender is for, I tell them I don't have enough money to keep the light there, so it's vacant until the car has to pass inspection. My fender clip is so rusted and mangled, it won't hold onto it at all. I don't mind, I'm too lazy to find a perm solution
Old 05-13-2019, 12:54 AM   #104
Takumidesh
Takumidesh's Avatar
Drives: 2013 FR-S, 2015 TC
Finally have gotten used to sinking down what feels like 5 feet when I go to sit in it and then having to crawl out of the car like Danny DeVito in always sunny climbing out of the couch.
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY
KANSAI DORIFTO
Takumidesh is offline   Reply With Quote
Old 05-13-2019, 01:01 AM   #105
I suggest you just glue it back on. Seriously, I had a marker light come off mrs humfrz's car and I simply glued it on and it's lasted for 2 years now.
DarkPira7e (05-13-2019), Feistyfrog (05-13-2019)
Old 05-13-2019, 04:43 AM   #106
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I got used to this car, so when I drive another car, I don't know how to drive.
IG: @rearwheelclub
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
gravitylover (05-13-2019)
Old 05-13-2019, 10:03 AM   #107
DarkSunrise
DarkSunrise's Avatar
Yeah my understanding was that engine braking was dependent on CR and multiplied through the gearing. But your comment got me thinking about the CR part and whether that's true. Turns out when the engine is off-throttle, it does slow the engine in the compression stroke, but returns most of that energy in the power stroke (essentially like a spring that's being compressed and released). So CR may not have as big of an impact if any on engine braking as I thought.
Some interesting discussion here:
https://www.carthrottle.com/post/the...ngine-braking/
https://www.lfs.net/forum/thread/582...t-really-works
https://jalopnik.com/actually-engine...ine-1818491096
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Adam_L (05-13-2019), Feistyfrog (05-13-2019)
Old 05-13-2019, 10:55 AM   #108
gravitylover
hmmm..... do you drive a lot when you "dress up" ..??
Ha!
The Following User Says Thank You to gravitylover For This Useful Post:
humfrz (05-13-2019)
Old 05-13-2019, 10:59 AM   #109
HaXx
Drives: jrsc_brz
Great idea for a topic!
1. 4% tint windows
2. Invidia N1 catback noise
3. The urge to build boost everywhere
HaXx is offline   Reply With Quote
Old 05-13-2019, 11:23 AM   #110
spencerpedia
spencerpedia's Avatar
Drives: 2013 White Subaru BRZ Limited
I don't have an ignition lol. (Push start Hyperblue BRZ because I'm extra AF) I guess just don't press the clutch when I hit the on button?
If you need to get into ignition just don’t put your foot on the clutch and press the start button twice, that should get it power on!
-2013 BRZ Limited SWP
spencerpedia is offline   Reply With Quote
The Following User Says Thank You to spencerpedia For This Useful Post:
p1l0t (05-13-2019)
Old 05-13-2019, 01:00 PM   #111
ermax
ermax's Avatar
I think the greatest impact on engine braking is the annoying computer. Turn off the car to experience what engine braking would be capable of if the ECU wasn’t involved. I wish the FA20 engine braked a little more than it does. I’m sure if I was more experienced in tuning I could improve on it some.
Old 05-13-2019, 04:30 PM   #112
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
would it actually be safe for me to turn off my engine to engine break?
I want to try this just to feel the difference you are alluding to
But i dont want to wreck my car lol
RickyRacer is offline   Reply With Quote
The little things... Be-Are-Zee BRZ First-Gen (2012+) — General Topics 130 04-26-2016 07:00 PM
Things on your car that you have grown to like... JD001 BRZ First-Gen (2012+) — General Topics 109 04-03-2016 04:28 PM
Has anybody grown attached to their stock wheels? FR_Soldier_77 Scion FR-S / Toyota 86 GT86 General Forum 43 02-06-2013 03:07 PM
