#15 | |
Benz Tech
Drives: 2017 BRZ Premium
A software update is just that, a software update. Usually the first step in any transmission complaint, flash up the newest software. Along with check the fluid level and verify the complaint. |
#16 | ||
http://www.ft86club.com/forums/attac...6&d=1386706237 Occurs in idle with the AC off. Quote:
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Arrex (05-10-2019) |
#17 |
Benz Tech
Idling with the AC off isn't slamming gears while coming to stop. I just can't connect the two.
Torque converter stuck on while you're coming to a stop feels like lugging a manual car. Torque converter stuck on during shifts often feels like a nasty shudder. Our vans have an issue where the torque converter can't dump pressure fast enough when shifting, and just before you stop. It feels like you hit the rumble strip. We replace the valve body and relearn the torque converter, there's a fix online to drill a hole in one of the valve body end plates to allow pressure to bleed off faster. I may or may not have have done it before, and it may or may have worked. A dip in RPM will give that nice shake though the car while it fights to idle, but it's not the same as when the torque converter is sticking. |
#18 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
This is a long shot, but consider this:
Get a can of carb cleaner and clean your maf and throttle bore (ideally take both out, and clean the throttle with a cleaner-soaked rag rather than spraying it directly). It might seem unrelated, but at 55k miles you're probably got some accumulated dust on the maf and oil soaked carbon in the throttle bore. The transmission tries to adapt to the engine load, and the maf is usually the main signal for that, it doesn't have to be way off, but a dirty maf's error will be worse near idle and send a slightly wrong load signal to the transmission, which is where you're having your problem. Same with a dirty throttle, cars used to have idle control solenoids or stepper motors that would control an air bypass around the throttle to control idle speed, now that is done by the throttle plate closing further than it's neutral closed position into a finely machined section of the bore. Even if the engine computer can adapt to the carbon and correct it's idle speed to a certain point, it can cause the engine to behave strangely as the throttle plate hunts around the carbon "steps" to get the desired idle. As I said, it's a long shot, but you're in it for the cost of a can of carb cleaner and 30 minutes. |
#19 | |
Went to another dealer inquiring about this, they plugged the computer in and told me my vehicle software are all up to date. |
| The Following User Says Thank You to Arrex For This Useful Post: | Dadhawk (05-10-2019) |
#20 | |
Benz Tech
#21 | |
#22 | |
#23 | |
Drives: Halo 86, '19
However I did read in the development article of the car (it's on the forums here somewhere) that supposedly shifter feel was deliberate on the AT, according to the AT development team. It sounds odd to me as I feel like any sensation presented in AT-MT mode would just be a sign of inefficiency or more drivetrain stress. Wouldn't smooth shifts be better all around? /shrug |
#24 | |
I have a feeling at this point Totoyta will use any opportunity to say these symptoms are "normal" because they don't have any idea what's causing it and / or so they don't have to fix it for us. Best wishes to you though hope your car doesn't get worse! |
| The Following User Says Thank You to Arrex For This Useful Post: | OwlDance (05-15-2019) |
#25 |
Drives: 2014 Toyota FRS
Simple fix ... costly but should have been done from the factory ...
Buy a manual transmission... |
#26 |
Drives: 2013 BRZ Sport-tech WRB
I'm also having this issue, and I also only started noticing it after a ATF change. I think it had more to do with the ECU relearn process than the actual fluid change.
I've done a quick cleaning on my throttle body, which seemed to fix it temporarily (again, I think related to ECU relearn from disconnecting battery). I plan on cleaning the MAF next. I've actually had 2 stalls now when coming to a stop. |
#27 |
Drives: 2017 BRZ
I believe the auto boxes in the Lexus IS are the same as the ones in the BRZ. I experienced the same thing when driving my brother's IS350. Shifts are smooth in auto mode but very rough in manual. It jolts you when coming to a stop, almost like someone who can't drive manual well. It gets to the point where you don't want to use the paddle shifters anymore.
#28 | |
| Tags |
| transmission issue |
| Automatic Supercharged Gt86 Shifting Issue | Nawar | Forced Induction | 9 | 02-10-2019 02:25 AM |
| *Automatic* Second Gear Issue!! | Donovan34 | Engine, Exhaust, Transmission | 11 | 08-25-2017 10:40 AM |
| Automatic Transmission Issue or ECU? | OpteronO3 | Issues | Warranty | Recalls / TSB | 8 | 09-15-2015 12:04 AM |
| Transmission issue P.S.A.... | 5AD86D | Issues | Warranty | Recalls / TSB | 10 | 06-22-2015 10:19 PM |
| Transmission issue | oppiee | Issues | Warranty | Recalls / TSB | 12 | 05-13-2015 04:11 AM |
