Old 05-07-2019, 07:28 PM   #20777
new2subaru
Weight Weenie
Drives: 15 FR-S
Went on a drive with the Ohlins set at 12F&R. Interesting experience. Cushy but not "sporty"
Old 05-07-2019, 07:35 PM   #20778
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
12K front and rear?
aint that hyper stiff?
Clutch Dog is offline   Reply With Quote
Old 05-07-2019, 07:38 PM   #20779
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Clutch Dog View Post
12K front and rear?
I have the Ohlins 4k 3k version. 12 clicks from full stiff. I normally have them set at 6&6 for street.
The Following User Says Thank You to new2subaru For This Useful Post:
Clutch Dog (05-10-2019)
Old 05-07-2019, 07:40 PM   #20780
Originally Posted by qcbaker View Post
Replaced my gas cap.
CEL came on with no other symptoms, so first thing I did was take the cap off and put it back on. CEL went away after a couple restarts. Same thing happened a few times over the course of last week, each time the light going away after I tighten the cap and restart the car a couple times. Went to Autozone over lunch today, gave them my year make and model, they said they didn't have any caps in stock. I told them to check if they had any for the BRZ or Toyota 86, and they had ones for the BRZ. So I bought one of those for $11. Fit perfect, no CEL so far
Kiss your warranty goodbye -
qcbaker (05-08-2019)
Old 05-07-2019, 07:41 PM   #20781
Originally Posted by RToyo86 View Post
Took apart and serviced the rear brakes as I could hear them sticking a little bit.
No brake service is complete without one busted knuckle.
So, when are you going to do the other side -
Old 05-08-2019, 04:14 PM   #20782
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Had mobile installer throw on my new enkei ts9's
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 05-08-2019, 10:45 PM   #20783
Ashikabi
Ashikabi's Avatar
How's the mobile vs tire shop prices?
Old 05-08-2019, 11:05 PM   #20784
Rican_D
Rican_D's Avatar
The one that I dealt with was hands down amazing. I bought new wheels because the TSP6 wheels I have were scratched up by last tire shop. These guys were top notch. Came in a box truck, they have a generator too. Swapped the tires to new wheels, road force balanced, and nitrogen filled. All done where I live.
Old 05-09-2019, 12:59 AM   #20785
JD001
JD001's Avatar
Drives: Subaru BRZ
Ask for a refund as he's turned your Twin into a Celica..
The Following User Says Thank You to JD001 For This Useful Post:
MJones_RB (05-09-2019)
Old 05-10-2019, 07:37 PM   #20786
Karfield
Drives: RS
Installed my Titan 7 Wheels 18X9.5 +40 today finally.
BFG Comp 2 A/S tires. 235/40/18 front with a 3MM Spacer. 255/35/18 Back.
So close on that stock perch.
Karfield is offline   Reply With Quote
The Following 3 Users Say Thank You to Karfield For This Useful Post:
DaBoBo21 (05-14-2019), MJones_RB (05-13-2019), Raven86Project (05-14-2019)
Old 05-10-2019, 10:58 PM   #20787
orz
orz's Avatar
Drives: Halo
Installed the Nameless 5" Muffled Track Pipe and Perrin Crank Pulley
Notes: 95 dbA is the legal limit for vehicle exhaust noise in California.
Standard Sound Test Procedures: 45Degrees 17.5-20 inches away from exhaust tip. 50% or 75% RPM Band.
OEM Crank Pulley: 5lbs
OEM Bolts: 70.3g
OEM Exhaust Hanger: 65.7g
OEM Muffler: 28lbs
Idle: 65.6dba
3700rpm: 79.2dba
5550rpm: 87.6dba
Perrin Crank Pulley: 1.2lbs
Nameless Bolts: 79.6g
Nameless Muffled Track Pipe: 5.5lbs
Idle: 73.6dba
3700rpm: 87.2dba
5550rpm: 100dba
FT86SpeedFactory Exhaust Cover: 142.1g
Total Savings: 22.5lbs + 3.7lbs + 3x(65.7g) + 9.3g -142.1g
= 25.9lbs + 64.3g.
Final Thoughts: The Perrin Crank Pulley alone wasn't much, but paired with the rpf1's at -5lbs/corner does make it feel more responsive and zippy. The exhaust sounds sporty, very much alive, and daily drive-able. I couldn't get any tests past 5550rpm due to the OFT's launch control settings, but if you are worried about the noise limit you should pass in an event of a citation.(depending if they use the 50% or 75% RPM test). I doubt an uncatted UEL/EL will pass so stick with the stock setup or get a catted one to be safe.
OEM bolts are lighter so I will reuse them.
orz is offline   Reply With Quote
The Following 2 Users Say Thank You to orz For This Useful Post:
MJones_RB (05-13-2019), new2subaru (05-13-2019)
Old 05-13-2019, 10:51 PM   #20788
new2subaru
Weight Weenie
Drives: 15 FR-S
Drove it at 7C in the rain on summer tires. I felt like I was driving on hockey pucks! Tomorrow promises 14C
Old 05-13-2019, 11:09 PM   #20789
StraightOuttaCanadaEh
Wes
Really? Is this on 215s and stock wheels? I’m in ontario too and unless there’s snow on the ground, summer tires feel super planted. MPSS in 225 on a 8” wide wheel were planted but still playful and I could kick the back end out at will, but now Firehawks in 255 on a 9” wheel result in immortal grip basically no matter the weather
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Feistyfrog (05-13-2019)
Old 05-13-2019, 11:25 PM   #20790
new2subaru
Weight Weenie
Drives: 15 FR-S
"Really? Is this on 215s and stock wheels? I’m in ontario too and unless there’s snow on the ground, summer tires feel super planted. MPSS in 225 on a 8” wide wheel were planted but still playful and I could kick the back end out at will, but now Firehawks in 255 on a 9” wheel result in immortal grip basically no matter the weather"
Firehawks 225/50 R16. They def don't feel planted...there's a major difference when it warms up more. I'm very careful when driving in the wet, especially when cool.
