Old 03-04-2019, 02:34 PM   #43
xjohnx
Grip>Slip
xjohnx's Avatar
I think you may be right about the aftermarket parts though. If you read through the Subaru instructions (did not review Toyota) on page 3 it says:
So at minimum it would appear that Subaru may be willing to pay for the workaround if it's reasonable.
Thank you a thousand times for this.
Old 03-04-2019, 02:38 PM   #44
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by shiumai View Post
It's not going to take an hour to remove the edelbrock SC and return to stock. That's going to take about 6 hours.
My dealer refused to take the car unless it had been returned to stock. Contacted Subaru USA and after a week or so of back and forth they agreed with the dealer. They also refused to help in any way to cover the cost of SC removal and return to stock.
So, I have not done the recall so far.
They don't have to take it off to return it to stock. Read the instructions linked above, nowhere in any of Subaru's documentation does it state the vehicle must be in stock form. It actually says the exact opposite.
They have to work around and accommodate the mods. It may take an extra 30 minutes to remove the SC as it would to remove the stock intake manifold. SOA would approve this extra time. The dealer just has to call them to get it approved. They'd rather you pay it because you pay full rate.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
shiumai (03-04-2019), sroby (05-11-2019)
Old 03-04-2019, 04:51 PM   #45
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
The service manager doesn't want to deal with re-installing the supercharger; hence will not take the car unless it's returned to stock, and will not warranty the work because of the aftermarket parts. I do see his point - if something goes wrong after the recall work is done, I'm going to point the finger to his work, and he's going to point the finger to the mods. After seeing the thread with people having problems after the recall work was done, I'm not planning on getting it done unless I'm forced to, in order to register my vehicle next year.
I've read the instructions, and spoke several times to the service manager, and Subaru. I do hope you're right and I'll wait to see how your case goes.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
ermax (03-04-2019)
Old 03-04-2019, 09:36 PM   #46
1stGenBRZ86
1stGenBRZ86's Avatar
Originally Posted by olsonpg View Post
I hear you. The shop that built my engine and installed my kit quoted me upwards of 20-25 hours to do the job. They basically told me if it was their car they didn't think it was worth 4-5k (CAD$) of preventative maintenance for a possible valve spring fault that may or may not wreck the engine if it breaks.
I don't know if I trust a dealership messing with my engine either since its so heavily modified.
I'm in a bit of a pickle but I almost think I'm just going to roll the dice on this one...
Anyone else feeling this way or am I silly to gamble on this.
if your motor is built, why do you have to do the recall? I'd assume if you have aftermarket valve springs, this wont be an issue. but i'm in the same boat as you...this recall came out about a month or two after I swapped my blown motor for another '13 motor (i'm turbocharged). I will also be rolling the dice...worst case, I'll build my original heads
1stGenBRZ86 is offline   Reply With Quote
Old 03-05-2019, 08:07 AM   #47
The service manager doesn't want to deal with re-installing the supercharger;....
Sounds like you need to find a new dealer, not only for service, but for future purchases.
CxG (04-08-2019), shiumai (03-05-2019)
Old 03-05-2019, 11:58 AM   #48
xjohnx
Grip>Slip
xjohnx's Avatar
I have obtained a copy of an email from a Subaru district manager confirming they they are working against the spirit of the agreement Subaru entered into with the NHTSA. How could these items be a "substantial safety concern"if they previously offered a quote for uninstalling and reinstalling them??
Keep digging that hole Subaru, this email will get tacked on to my already open NHTSA investigation.
The Following 3 Users Say Thank You to xjohnx For This Useful Post:
CxG (04-08-2019), Dadhawk (03-05-2019), shiumai (03-05-2019)
Old 03-05-2019, 12:17 PM   #49
shiumai
shiumai's Avatar
[quote=Dadhawk;3192302]
The service manager doesn't want to deal with re-installing the supercharger;....QUOTE]
I bought the car from another dealer. Trouble is, it's quite far away while this one is about a mile from my house. Up until this matter, the closer dealership has always been pretty good with service.
Old 03-05-2019, 09:04 PM   #50
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
I don't, we didnt touch the valvetrain unfortunately.
Yeah my shop that built my engine basically said that the chance of failure is small, and even if there is a failure the chances of a catastrophic engine failure are smaller yet, and "usually" there is a tell that something is going bad with some very ferocious ticking so there is a chance to save it before things get really bad.
Crossing my fingers for you and me!
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
The Following User Says Thank You to olsonpg For This Useful Post:
1stGenBRZ86 (03-05-2019)
Old 03-06-2019, 09:18 AM   #51
xjohnx
Grip>Slip
xjohnx's Avatar
If your dealer is refusing to perform the recall without you paying to have mods removed, I implore you to open an NHTSA investigation at the following link:
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
This is explicitly against the agreement that Subaru entered into with the NHTSA and puts them out of compliance. Dealerships are going to keep doing this until they're held accountable to the law. File these reports and let the dealership know you are doing it. They are subject to a fine of up to $21,780 for each vehicle they refuse.
The Following 4 Users Say Thank You to xjohnx For This Useful Post:
CxG (04-08-2019), mswbrz (03-20-2019), sroby (05-11-2019), Turbo (03-28-2019)
Old 03-20-2019, 07:49 PM   #52
Bunsin
Car Goes Bang
Drives: 2013 FRS, 2014 BRZ
I told them I would give them two hours and they refused for anything less than 8-12. Went all the way up to the regional service manager to get approval for ‘only 5’ extra hours. I have over 1500 miles on it post recal and no issues.
Bunsin is offline   Reply With Quote
Old 03-21-2019, 01:07 PM   #53
toast
Drives: 14 BSP Edelbrock BRZ
I can't understand why anyone would want the mechanics at the dealership to touch anything involved with something they haven't been trained on. Personally, even if my car were stock I would roll the dice on the springs since several cars that were 'repaired' by dealerships then failed because they don't know how to correctly apply RTV sealant.
If you are set on having them do it, pull the SC yourself, stuff rags into the intake holes and have the car towed to the dealership. Let them do the heads and then reassemble it yourself.
toast is offline   Reply With Quote
Old 05-08-2019, 07:08 PM   #54
gt86drifter4life
Drives: Scion FRS
Does anyone know of a dealership in northern California that is willing to do the recall on the car with a supercharger? I've tried calling just about every dealership and all of them require the car to be in stock form.
gt86drifter4life is offline   Reply With Quote
Old 05-08-2019, 07:11 PM   #55
StraightOuttaCanadaEh
Wes
Originally Posted by gt86drifter4life View Post
Does anyone know of a dealership in Northern California that is willing to do the recall on the car with a supercharger? I've tried calling just about every dealership and all of them require the car to be in stock form.
Since this is your first post, I guess I have to let you know that some people here came to the conclusion that if nothing's gone wrong on your car by now, best to leave it alone. A lot of cars failed after the recall work was done. It's a very precise procedure and they're simply not competent enough to perform it.
Instagram: @gt86ws
Old 05-08-2019, 07:16 PM   #56
gt86drifter4life
Drives: Scion FRS
I am aware of that. One of the dealerships I called said they have performed 17 successful recalls so far, not sure if they are to be believed haha.
2013 Scion FR-S Valve Spring Replacement Recall Aussie Northern California 29 06-22-2020 01:51 AM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
Valve Spring Recall Resolved!!! hgamit Issues | Warranty | Recalls / TSB 32 02-23-2019 10:00 PM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 11:09 AM
