#15 |
Well.... definitely found something not right.
The left hand intake valve does not seem to open/close while rolling the crankshaft over. About to do a quick leak down test to confirm it's not fully sealed but pretty clear that something isnt right. The question is whether or not this is traceable back to bad recall springs or not. Sent from my SM-N950U using Tapatalk |
#16 | |
Benz Tech
Drives: 2017 BRZ Premium
Often nothing else is damaged. Replace the valve and move on. Should be covered under the recall. It will be more work, the head will have to be removed. Good luck! |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| valve spring issue? | nikitopo | Issues | Warranty | Recalls / TSB | 1037 | 05-01-2019 10:55 PM |
| Valve Spring Failure With Forced Induction? | mrhemi | Forced Induction | 2 | 03-17-2019 07:35 AM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
