CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 11-21-2018, 08:15 PM   #2101
Pat
Pat's Avatar
Drives: 2023 BRZ
Looks cushy.
The Following User Says Thank You to Pat For This Useful Post:
ATL BRZ (11-21-2018)
Old 11-26-2018, 04:58 PM   #2102
Seats look good! What's your height/weight/waistsize?
- Andrew
ATL BRZ (11-27-2018), jflogerzi (01-09-2019)
Old 11-27-2018, 02:41 AM   #2103
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
- Andrew
Thanks! I'm 5'10/185/34
The Following User Says Thank You to ATL BRZ For This Useful Post:
Racecomp Engineering (11-27-2018)
Old 11-27-2018, 09:42 AM   #2104
TheStig85
Drives: 2013 Subaru BRZ
T H I C C
Sent from my Pixel 2 XL using Tapatalk
TheStig85 is offline   Reply With Quote
The Following 4 Users Say Thank You to TheStig85 For This Useful Post:
ATL BRZ (11-28-2018), ka-titties (05-14-2019), MCTeeJ (11-27-2018), Trust86 (02-17-2019)
Old 01-08-2019, 03:12 PM   #2105
ATL BRZ
ATL BRZ's Avatar
Nothing really substantial to update other than some sweet new LED garage lights!
They really light the place up!
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
aimforapex (01-29-2019), Conman (05-14-2019), DocWalt (01-09-2019), MCTeeJ (01-08-2019), mistople (01-08-2019)
Old 02-16-2019, 11:41 PM   #2106
ATL BRZ
ATL BRZ's Avatar
Debated for too long between getting Quickjacks or a new jack and stands. Ended up with a set of ESCO stands and an Arcan low profile jack that lifts the car higher than Quickjacks up to 21 inches!! Glad I saved the $800 and got this setup. I can set it up quicker and it's very secure on the padded stands.
The Following 7 Users Say Thank You to ATL BRZ For This Useful Post:
jflogerzi (02-17-2019), MCTeeJ (02-18-2019), new2subaru (02-18-2019), pgranberg11 (06-11-2019), Rosticles (05-07-2019), TeutonicShift89 (02-17-2019), TheStig85 (02-16-2019)
Old 05-07-2019, 03:32 AM   #2107
WC-BRZ
Drives: Black BRZ
Was hoping to get some info on how the stock engine finally gave up? Was it during a track day and were you on the 300-ish whp tune? Any particular cause based on a specific parameter (oil temp, press, etc?).
You decided to go with Mazworx for the engine build - how is the new motor holding up? Any oil burning issues? What is the tune like for the built engine and is it being used as a daily or just for autocross/track days?
And, finally, how is the transmission holding up?
Thanks for sharing!
WC-BRZ is offline   Reply With Quote
Old 05-07-2019, 04:37 PM   #2108
ATL BRZ
ATL BRZ's Avatar
Temps and pressures were nominal and the tune was on point. A connecting rod bent after a pull at 14psi (~400whp) on the street, close to home.
New engine is holding up fine, however I am currently patching small oil leaks from bottom of the timing cover.
The tune is based on the same one I was running before. Car is still street driven occasionally but mostly built for track days.
No issues with the transmission.
Old 05-07-2019, 06:18 PM   #2109
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
You maniac!
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
ATL BRZ (05-07-2019)
Old 05-13-2019, 06:11 PM   #2110
jflogerzi
jflogerzi's Avatar
Your car looks soooo good! I smile when I see pictures of it. I would love to see your car in person if your ever in CA.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
ATL BRZ (05-13-2019)
Old 05-14-2019, 04:04 PM   #2111
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
If I may ask, do you mean patching in the literal sense, or doing a reseal on the timing cover? I ask because mine has leaked for years and if there's a good patch method I'd love to hear it.
MCTeeJ is offline   Reply With Quote
Old 05-14-2019, 04:26 PM   #2112
ATL BRZ
ATL BRZ's Avatar
Patching the outside where it's leaking using Permatex Ultra Grey/Black sealant. I'm really trying to avoid a full reseal of the timing cover as it's incredibly laborious and the leak isn't bad enough to warrant it at this point. It's more annoying than it is a risk to the engine. Plenty of stock, unmolested FA20's leak from the cover, and I consider myself lucky to only have a minor leak.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
MCTeeJ (05-15-2019), TheStig85 (05-14-2019)
Old 05-15-2019, 09:46 AM   #2113
MCTeeJ
MCTeeJ's Avatar
Hmm. Got any pics? If it doesn't leak then I may have to try this out myself. Thanks btw.
The Following User Says Thank You to MCTeeJ For This Useful Post:
BigTuna (05-15-2019)
Old 06-11-2019, 01:15 PM   #2114
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I just noticed how baller this setup is. Maybe the next thing I do, harbor freight shit is getting old...
pgranberg11 is offline   Reply With Quote
The Following 2 Users Say Thank You to pgranberg11 For This Useful Post:
ATL BRZ (06-12-2019), MCTeeJ (06-11-2019)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
