Old 05-06-2019, 07:29 PM   #1
Aluma007
Drives: 2017 Brz
snap in harness
Hey y'all, wondering if anyone knows where I can find a red version of the Takata 74000US-0 drift harness I saw on amazon. It looks like it attached to the rear seat anchors I'm guessing some bolts under the seat. I do autocross once in a while and I'd like to try one out. The less expensive the better.
If you have one, please post pics of how its mounted too. Thank you!
Aluma007 is offline   Reply With Quote
Old 05-06-2019, 10:29 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
CG Lock
Old 05-07-2019, 08:24 AM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Something free:
- When you're in your car before a run, scoot your seat back and pull the belt tight across your lap.
- Give the upper part of the belt, at your shoulder a quick yank to lock it.
- While keeping tension on the belt, scoot your seat forward to your normal position.
- The seatbelt should be tight across your body and the tension keeps it locked.
BigTuna is offline   Reply With Quote
Old 05-07-2019, 08:41 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
BigTuna: PITA to do for every 15min session.
Old 05-07-2019, 09:32 AM   #5
JoeC
Drives: Subaru BRZ Limited
Originally Posted by x808drifter View Post
CG Lock
I'll second this. I have one and like it.
JoeC is offline   Reply With Quote
Old 05-07-2019, 10:04 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
I'd wish for someone to design/make cg-lock alike to pretension & fix belt at shoulder area aswell though. So far BigTuna's mentioned method with stock harness seems only way . CG-lock does it's job for lap part, but not for neck/shoulder upper belt part.
Old 05-07-2019, 07:52 PM   #7
Aluma007
Drives: 2017 Brz
yeah, thats what I was thinking...the shoulder belt tends to dig into my neck and its annoying as hell. I had seen the cg lock, but didn't think it'd do anything about the neck area, so I went looking for something like the snap in harness. I've done the other things to try to keep it snug but its not enough...I guess it can't keep that much mass in place. :P
Then there's the helmet hits the liner thing, but there's not much to do but lean the seat back. :/ Oh well, love this damn car, enjoy it anyway I can.
Old 05-07-2019, 10:05 PM   #8
x808drifter
LMGTFY
Do you flip the headrest around to give more helmet clearance?
Old 05-07-2019, 10:20 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
x808drifter: that won't do much if it's roof that helmet is touching. What would solve - lover seats, or closer to driver steering wheel that would allow reclining back of seat further back or removing roof lining.
Problem - none of these options go along lines of minimum change to stock (seat/steering wheel/interior/safety systems) and are cheap, in fashion of CG-lock.
Aluma007: i'd wait, maybe soon there will be wheel spacer by 949 Racing to allow putting stock wheel closer to driver. DDPerformance maybe might lower stock seat by modding it's base & mount.
x808drifter (05-08-2019)
Old 05-07-2019, 11:28 PM   #10
Aluma007
Drives: 2017 Brz
hadn't tried that, but its not the part that touches...its the top of the helmet that hits the ceiling...so i usually lean seat a little back, and scootch down a little on the seat too. I guess its okay at that point since its like support for the helmet since it still touches the side a little bit on really hard corners.
I'd just like to have a harness that clips in to the rear child seat anchors and maybe uses the lap belt clip and something on the bottom on the opposite end. Thats what the takata looks like from the pics...just that $200 to $300 seems a bit steep...I could get RCE springs for that much instead.
The Following User Says Thank You to Aluma007 For This Useful Post:
Old 05-07-2019, 11:52 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Aluma007: i suggest not to get that harness. Using it may get very dangerous.
Problem stems from safety devices working as system.
Stock you have seat that can give and crumble in case of rollover, belt that allow upper torso to move a bit before lock, positioning in right place for airbags and so on. Stock also has wide range of adjustments to put seat/yourself at right place/pose for other safety devices to work right.
Then there is sport "set" - with multipoint harness you are fixed in bucket seats, whose back won't give in case of rollover - thus you need rollcage to not splash your head being fixed unmovable in strong constructed seat. And helmet, to not split skull against rollcage .. but both sport seat and helmet (and hans-device) will reduce visibility.
In most cases any halfmeasures in between these "full sets" are illegal on street and not allowed also on tracks/events, where organisators check/regulate/enforce safety.
Adding 4-point harness to everything rest stock can make you not positioned right for airbags, can increase head injury rollover dangers, and then there is danger of damage in crotch area due submarining effect. At most i'd consider only Scrotch 4pt harness with anti submarining system for track (unfortunately they don't make 4pt ASM harness for twins), and stock belt everywhere else, but otherwise right way is "all or everything stock". Full sport set of seat/cage/mpoint harness/helmet on track (unfortunately not street legal, so for track only car brought around on trailer), and all stock (+helmet/cg-lock for track) for only daily driven or for car used both on street & track.
Yes, stock harness hampers a bit enjoyment of track due not fixing well in (stock) seat (with less side bolstering then bucket seats) .. but it's legal/allowed/requires no extra spending. Don't go for track slicks/lot of aero downforce/for high grip & side-Gs, enjoy trackdays in more down to earth car, and in many cases stock seats & harness may do relatively fine.
Aluma007 (05-08-2019)
Old 05-08-2019, 01:01 PM   #12
evomike
Drives: frs
I would worry about spinal compression using a harness like that with no harness bar.
evomike is offline   Reply With Quote
Old 05-08-2019, 09:28 PM   #13
Aluma007
Drives: 2017 Brz
cglock and seat belt pad it is...
Thank you all for the input.
SOLD Takata Drift II 4pt Harness Green Snap On 2 Seat Belt ASM Anti Sub Equipped hirollaz Interior Parts (Incl. Lighting) 4 04-02-2015 02:50 PM
**CIPHERAUTO HARNESS BAR AND SFI APPROVED HARNESS BELTS!** genometuning Interior Parts (Incl. Lighting) 59 01-09-2015 01:55 PM
Sold: 2x Cipher Racing Harness Set 4 Point 2 Inch and Harness Bar siuhen Interior Parts (Incl. Lighting) 12 12-27-2014 09:38 AM
XM Snap + 3 months $20 Aznek CANADA 5 04-02-2013 01:55 PM
Ohh snap, it's an FRS! siXXtoes Member's Car Journals 12 12-05-2012 02:14 PM
