Old 05-06-2019, 07:22 PM   #1
Jcas
Jcas's Avatar
Drives: 2013 Limited Subaru BRZ
Question GT2860RS with JDL turbo kit
So I was wondering how close of a fit it would be with the GT2860RS turbo and stock fans? I know from what I’ve seen looks close and it might melt some of the fan? So I was thinking if I cut it a little bit and get a turbo blanket I’d be okay? Any opinions?
Jcas is offline   Reply With Quote
Old 05-06-2019, 11:35 PM   #2
jflogerzi
jflogerzi's Avatar
Your probably gonna want a slim fan/shroud to mate up to the stock radiator. Not much room in our engine bay.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 05-07-2019, 12:01 AM   #3
incutebus
Drives: Boosted
I trimmed down the fan shroud and fit a turbo blanket over. You're not going to be able to tie it down at the bottom so you're going to need a different method of tying it down. I used 2 metal wires and tied it down from top to bottom.
You're gonna be hitting the fan shroud still, but you won't come into contact with the fans.
incutebus is offline   Reply With Quote
Old 05-08-2019, 04:36 AM   #4
djezlee
Drives: 2017 BRZ Limited
I suggest getting a slim shroud. I just did the install, and I am happy I have slim shroud.
djezlee is offline   Reply With Quote
Old 05-08-2019, 10:37 PM   #5
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Slim fan shroud is ideal but the 2860 will fit with OEM. Connector at the bottom needs to be moved by the downpipe, the plastic by the turbo generally can tolerate some pretty high temps since air is constantly flowing there and blowing away from the fans. With that said on our setup we're going with a slim shroud/spal fans to not have to worry about it.
Xero-Limit is offline   Reply With Quote
Old 05-11-2019, 11:47 PM   #6
Conman
Conman's Avatar
Drives: Red FRS
Okay thanks good to know. I’m going to give it a go with the stock shroud. I just ordered the same kit. V2 w/gt2860r.
Conman is offline   Reply With Quote
jdl, turbo, turbo kit
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA bren5279 Engine, Exhaust, Bolt-Ons 69 06-29-2015 10:56 PM
FS:A Garrett turbo,& a Greddy turbo kit with extra parts. Cessblood Engine, Exhaust, Bolt-Ons 76 02-18-2015 08:47 AM
