Old 04-30-2019, 02:09 PM   #1
boomslang
Drives: Toyota
Boomslang Emtron Toyota 86 / BRZ / FR-S GM LS swap full PNP wiring kit
We are proud to announce a full PNP wiring solution for performing a Gen IV GM LS swap into the the Toyota 86, Scion FR-S or Subaru BRZ. All model years (2012-2019) are supported.
This kit was developed directly with Emtron USA.
This is a true PNP solution. Not a single wire needs to be cut to perform the installation of this kit. The harnesses are built using mil-spec Tefzel wire and Raychem DR-25 sleeving. Everything is built with new OEM connectors and terminals as a turnkey system.
  • The kit includes a complete GM LS engine harness, interior Emtron KV8 jumper harness, alternator harness, engine ground harnesses, starter and transmission harnesses.
  • The kit requires the use of an Emtron KV8 engine management system, which fully replaces the OEM 86 ECU.
  • The Emtron KV8 offers full engine control and OEM CAN bus support.
  • Key start and push button start vehicles are supported.
The full installation manual is attached to this thread.
Link to our Vendor classified section thread:
https://www.ft86club.com/forums/showthread.php?t=134417
Any questions? Just ask!
File Type: pdf Boomslang Emtron Toyota 86 GM LS Swap Harness Installation Manual VER 1.3.pdf (673.6 KB, 153 views)
boomslang is offline   Reply With Quote
The Following 7 Users Say Thank You to boomslang For This Useful Post:
Calum (05-02-2019), Draco_PR23 (05-03-2019), DustinS (04-30-2019), Kenny_LongWrench (07-19-2019), Sportsguy83 (04-30-2019), wparsons (05-02-2019), Zer0 (05-01-2019)
Old 05-02-2019, 09:54 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Are all gauges, AC, power steering, etc. working? Is anything not working? If so, is there a plan to get that working?
The Following User Says Thank You to Calum For This Useful Post:
Old 05-02-2019, 11:11 AM   #3
toast
Drives: 14 BSP Edelbrock BRZ
It's ok to have the harness connectors that close to the exhaust manifoled?
toast is offline   Reply With Quote
Old 05-02-2019, 01:10 PM   #4
boomslang
Drives: Toyota
The Emtron KV8 supports all the features of the car with their OEM 86 CAN integration. The OEM traction control system not longer functions, that function is performed by the Emtron KV8.
The Following User Says Thank You to boomslang For This Useful Post:
Calum (05-02-2019)
Old 05-02-2019, 01:22 PM   #5
boomslang
Drives: Toyota
The connectors are not particularly close to the exhaust manifold.
Boomslang Emtron Toyota 86 / BRZ / FR-S GM LS swap full PNP wiring kit. boomslang Engine Swap 0 04-30-2019 02:06 PM
Full exhaust swap? 2017 86 Toyota YgRoshi Engine, Exhaust, Transmission 9 03-27-2019 12:04 PM
V8 Swap wiring questions all4spl Engine Swaps 19 04-09-2018 03:59 PM
Full Dash including wiring C130NAV Want-To-Buy Requests 7 11-06-2014 11:57 AM
FS: Full Engine Wiring Harness DieselxIndustry Engine, Exhaust, Bolt-Ons 3 06-25-2013 03:14 PM
