Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Engine Swap
Engine Swap Engine swaps!
Old 04-30-2019, 01:06 PM   #1
boomslang
Drives: Toyota
Boomslang Emtron Toyota 86 / BRZ / FR-S GM LS swap full PNP wiring kit.
We are proud to announce a full PNP wiring solution for performing a Gen IV GM LS swap into the the Toyota 86, Scion FR-S or Subaru BRZ. All model years (2012-2019) are supported.
This kit was developed directly with Emtron USA.
This is a true PNP solution. Not a single wire needs to be cut to perform the installation of this kit. The harnesses are built using mil-spec Tefzel wire and Raychem DR-25 sleeving. Everything is built with new OEM connectors and terminals as a turnkey system.
  • The kit includes a complete GM LS engine harness, interior Emtron KV8 jumper harness, alternator harness, engine ground harnesses, starter and transmission harnesses.
  • The kit requires the use of an Emtron KV8 engine management system, which fully replaces the OEM 86 ECU.
  • The Emtron KV8 offers full engine control and OEM CAN bus support.
  • Key start and push button start vehicles are supported.
Retail on the full wiring kit only is $3700. You can add the Emtron KV8 unit with OEM 86 CAN integration for an additional $2665.
The full installation manual is attached to this thread.
Order here:
https://www.boomslang.com/toyota-86-swap.php
File Type: pdf Boomslang Emtron Toyota 86 GM LS Swap Harness Installation Manual VER 1.3.pdf (673.6 KB, 863 views)
boomslang is offline   Reply With Quote
Full exhaust swap? 2017 86 Toyota YgRoshi Engine, Exhaust, Transmission 9 03-27-2019 11:04 AM
V8 Swap wiring questions all4spl Engine Swaps 19 04-09-2018 02:59 PM
Newb Question, Can I use Oem wiring for full amplifier? YamahaR86 Electronics | Audio | NAV | Infotainment 12 04-28-2016 10:52 AM
Full Dash including wiring C130NAV Want-To-Buy Requests 7 11-06-2014 10:57 AM
FS: Full Engine Wiring Harness DieselxIndustry Engine, Exhaust, Bolt-Ons 3 06-25-2013 02:14 PM
