Old 04-08-2019, 12:37 AM   #2283
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Originally Posted by Simok View Post
Damn, and no fix yet it looks like
So has mine...m
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 04-08-2019, 12:50 AM   #2284
Impureclient
Drives: 2015 FR-S
[ame]https://www.youtube.com/watch?v=xDVY3IoQTT4[/ame]
Here are some of the comments translated from Russian:
Here is a setup from the manufacturer of car DEXP, the error is related to the calculation of the exact number of weeks through the exchange of data with GPS satellites, 0 April 6, 2019 was updated, and 0 7 no longer works.
TEMPORARY SOLUTION, raise likes! We take out the radio and unscrew the back of the GPS antenna. Navigation, respectively, stops working, but the error disappears, the radio works fine.
A similar situation ((. I couldn’t even find the firmware, I’ll take your word for it that the firmware will not help. I wonder what the solution will be?
***********OK so I got it running. You just have to kind of repeat what he did in the video. It was shutting off while trying it but in the end the date being set back one year and turning off those two check marks in GPS settings did it. If you go back into the GPS settings, they are checked every time so it seems lie it rechecks itself after you exit that menu setting, not sure. I also unplugged the GPS satellite from the back. So it's either the GPS setting, the date change or unplugging the antenna or some combination of that.
Old 04-09-2019, 01:00 PM   #2285
XtremeMaC
Drives: Asphalt Grey FR-S
Wow, extremely weird. I started having the same issue. I thought i messed it up. I did a factory reset. It didn't fix it. Turns out others having the same issue.
I'll try that even weirder solution to fix a voice update issue..
2013 Asphalt Grey FR-S MT VIN: 7086XX
XtremeMaC is offline   Reply With Quote
Old 04-12-2019, 11:05 PM   #2286
nphillip
nphillip's Avatar
Has anybody got a fix for the unit always rebooting itself?
I've owned the unit for roughly 3-4 years and it has been running smoothly. Just recently, the system has just been rebooting itself every 2 minutes or so. It happens both when using bluetooth to play music from my phone, and also when playing music in my SD card. Even when I'm not using the unit at all, it restarts.
I've been playing music from the same SD card for years, and have not added anything new onto it so I don't see the SD card being the problem.
I have tried resetting the unit, and doing a factory unit reset but no luck. Could it be a hardware problem?
Thanks.
nphillip is offline   Reply With Quote
Old 04-13-2019, 10:53 AM   #2287
Impureclient
Drives: 2015 FR-S
Nope...*looks at three posts up*....not at all. No fix for unit rebooting itself at all yet....
Old 04-13-2019, 11:54 PM   #2288
nphillip
nphillip's Avatar
Nope, obviously haven't tried it. Obviously...
Old 04-15-2019, 12:10 PM   #2289
computertech01
Drives: Jetta MK1V
Verified that unplugging the gps antenna does in fact fix the issue.
computertech01 is offline   Reply With Quote
Old 04-17-2019, 09:47 AM   #2290
nphillip
nphillip's Avatar
Have also tried this, still no luck.
Wtf.
Old 04-17-2019, 10:47 AM   #2291
Simok
Drives: 2013 FRS
Wtf.
Mine didnt work at first I had to reset the unit one more time. Also did you set the date back a year.
Simok is offline   Reply With Quote
The Following User Says Thank You to Simok For This Useful Post:
nphillip (04-17-2019)
Old 04-17-2019, 11:52 AM   #2292
Impureclient
Drives: 2015 FR-S
So ultimately it's looks just like unplug GPS antenna then reset. Resetting date was just an idea but that Russian video has them just unplugging and that doing it. Maybe the date can be even reset back to the right year after.
Or do all three things in this order, unplug GPS/reset year/reset unit to factory and then plug back in GPS and fix year to current and it will just be one year behind but with GPS still working but thinking it's just a year behind.
They did also say in the later comments that that manufacturer is looking into a firmware fix. It's not the same maker but the Android version and all the menu/options/etc all look the same so if that DEXP fixes it, it should be
a firmware fix for the Cafi too.
The Following User Says Thank You to Impureclient For This Useful Post:
Old 04-17-2019, 12:31 PM   #2293
Simok
Drives: 2013 FRS
Just to clarify my comment. I first unplugged gps from back, in the process of trying to changed date it kept reseting, so I pressed the little reset button in the upper right, which stoped the issue. I changed the date just in case.
Old 04-25-2019, 10:34 PM   #2294
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
seems it's time to remove and burn these units
86•BRZ is offline   Reply With Quote
Old 04-26-2019, 05:27 AM   #2295
born2lose
Drives: Toyota GT86
I actually still enjoy mine - and hope someone will find a fix. I’ve been looking for alternatives, but I can’t find a single one that will fit in the same way - no brackets, etc. If you have any suggestions, please share.
now, time to go back to the parking lot and disconnect the gps antenna... although it’s not of much use without the gps. I really hope the fix works...
l.e. disconnected the gps, changed the date to 2018, I have music and no more resets. whenever I try to reconnect the gps antenna, the date resets to 1963 and it all goes to crap. which is unfortunate, because that counts for 80% of it’s usefulness to me.
still open to any suggestions...
born2lose is offline   Reply With Quote
Old 04-26-2019, 08:08 AM   #2296
Simok
Drives: 2013 FRS
I emailed their tech support when it first happened and still havent heard anything back. Sucks that the unit was only good for a few years.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
