Old 04-24-2019, 08:45 PM   #15
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Talking
Originally Posted by kch View Post
Nope. The leak is really slow, so I'm just gonna ignore it for now.
cough same here.... is there a thread on this?? @Tcoat plz?
Old 04-24-2019, 09:14 PM   #16
https://www.ft86club.com/forums/showthread.php?t=133810
chaoskaze (04-24-2019)
Old 04-24-2019, 09:26 PM   #17
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Old 04-24-2019, 09:42 PM   #18
My rule of thumb in dealing with oil leaks over dozens of different types of engines for several decades is:
If it don't pool, burn, drip or lower the levels between changes then leave it the hell alone. Sure it ain't pretty but if appearance is an issue just clean it up every now and then. About half the time I tried to fix minor leaks I ended up with a bigger mess than when I started.
Calum (04-27-2019), chaoskaze (04-26-2019), churchx (04-25-2019), soundman98 (04-24-2019)
Old 04-24-2019, 10:59 PM   #19
toast
Drives: 14 BSP Edelbrock BRZ
Or you could go to a dealer, the tech squirts a whole tube of sealant on the mating surfaces and you wind up with a seized motor because the sealant clogged an oil passage. I agree with Tcoat, just wipe it up.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
Old 04-26-2019, 08:31 PM   #20
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Thanks for the advise Tcoat.
Definitely taking it.
Water Leak inside passenger side floorboard AtlasMick Issues | Warranty | Recalls / TSB 30 03-28-2019 05:43 PM
Fuel leak from top of tank, passenger side Ashikabi Engine, Exhaust, Transmission 0 02-27-2018 08:00 PM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 05:53 PM
Passenger door raddle and squeak coming from around speaker Peschi Issues | Warranty | Recalls / TSB 6 03-08-2015 03:58 PM
Relay Sound Coming From Passenger Side jjkerr626 Issues | Warranty | Recalls / TSB 0 10-06-2012 11:29 AM
