go_a_way1
Old 04-19-2019, 12:59 PM   #4929
HaXx
Drives: jrsc_brz
Originally Posted by DaveB.inVa View Post
In other words, keeping the same power output as a C30 supercharged vehicle, would the C38 be stressed less, generate less heat or anything because it is spinning slower?
From my understanding, power is generated from your amount of boost and boost is determined by pulley size, standard or high boost pulley. I dont think you can "down tune", just "shit toon". A c38 is going to make what it makes, tune dependant, and ur gonna want a good dynotune, not a crap "toon". Sound like you want the gold standard, reliable, not stressful to stock engine components, and that's exactly what the c30 it. It's what I have too, no supporting mods (no injectors/clutch/ or oil cooler), just a professional install and rock solid dynotune from a reputable shop. No drama, big fun.
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
DaveB.inVa (04-21-2019)
Old 04-19-2019, 02:27 PM   #4930
CSG Mike
CSG Mike's Avatar
In regards to the C30 or C38 kits, is there any advantage to supercharger life to run the C38?
Does anything make it worthwhile to spend the extra $100 for the C38 during an initial purchase if I'm only wanting about 240-250 whp?
I've searched and read through this thread over time and always read about those wanting more power from the C38 but I'd not seen any answers from that angle I guess.
I recommend the C30 for you. There is no difference in supercharger life.
mrg666 (04-20-2019)
Old 05-10-2019, 03:43 PM   #4931
snowdog
Drives: 2013 Scion FRS
I have been running for a few years without issue. However yesterday I have a CEL and thought I'd use my ecutek cable to see if it could tell me what code it was. Plugged in and software needed to be updated, So I updated. Detected vehicle and ran the Vehicle DTC Tool.
The following is what it showed me:
"Performing DTC Operations on...
Reading DTCs...
OBD Error during reading DTCs: No Response to ODB Request
End of DTC Operation
Any thoughts?
snowdog is offline   Reply With Quote
Old 05-10-2019, 05:42 PM   #4932
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Reading DTCs...
Any thoughts?
You try unplugging then replugging it in? Is it dirty?
JDMChris is offline   Reply With Quote
Old 05-10-2019, 07:11 PM   #4933
snowdog
ya, tried a couple of times.
Took it in to the auto parts store and tried their CEL reader.
P0390
P0391
Do you think this is tied to the tune or something else?
I would still like to know if others have had ECUtek DTC problems
Old 05-16-2019, 10:26 AM   #4934
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Originally Posted by axelthrasher View Post
It's boost season! I have some C30 JR supercharger stuff to sell for cheap:
$130 Jackson Racing High Boost Pulley
$75 Jackson Racing V2 hard pipe
Someone buy this stuff!
Price drop:
$100 Jackson Racing High Boost Pulley
$40 Jackson Racing V2 hard pipe
axelthrasher is offline   Reply With Quote
Old 05-20-2019, 09:51 PM   #4935
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Bit of a left field ask here:
I have the JR NA oil cooler currently installed. I plan on installing the JRSC along with the NA->FI conversion for the oil cooler. The conversion utilizes new cooler lines—any tips on how to avoid an oil spill all over my floor when swapping in the new lines?
mistople is offline   Reply With Quote
Old 05-20-2019, 10:56 PM   #4936
new2subaru
Weight Weenie
Drives: 15 FR-S
Drain it completely.
Old 05-21-2019, 02:50 PM   #4937
CSG Mike
CSG Mike's Avatar
Disconnect the cooler bracket. Remove cooler from the bracket.
Then disconnect the lines.
Keeping the end of the lines higher than the core, pull the assembly out of the car. This is like elevating a cut or wound to help it stop bleeding.
Drain the cooler, and you'll have no issues from here.
Old 05-24-2019, 11:24 PM   #4938
HaXx
Drives: jrsc_brz
Need for re-dyno after header install?
I'm boosted on c30, no supporting mods. I have a cat back on that was present during the s/c install/dynotune. 262/192 wheel.
I'm considering getting an el catless header now. If I need to retune I'll pass. If I can bolt on, no retune I might go for it.
Old 05-25-2019, 08:32 PM   #4939
ltown
Drives: 2013
can you run stock airbox on jackson racing kit?
ltown is offline   Reply With Quote
Old 05-26-2019, 11:01 AM   #4940
J1Avs
Drives: 2018 BRZ tS
I would definitely retune, if you were going catted, maybe you could get away with it, but with the additional airflow a catless EL is going to enable, I feel a tune is necessary to actually reap any major benefits out of it. Personally, I’m also of the mindset to want my tune to be 100% in line with what’s going on with my car, because with boost, any margin of error just doesn’t seem with the worth it.
J1Avs is offline   Reply With Quote
The Following User Says Thank You to J1Avs For This Useful Post:
HaXx (05-29-2019)
Old 05-26-2019, 11:01 AM   #4941
J1Avs
Drives: 2018 BRZ tS
Negative, no room. The JR comes with it’s own intake filter and pipe that feeds directly into the Rotrex.
Old 05-29-2019, 04:08 PM   #4942
J1Avs
Drives: 2018 BRZ tS
Also, if it helps put it in perspective. I currently run a catted JDL UEL (that’s gutted), with a JDL catless/resonated FP w/ my JRSC. On Friday, I’ll be swapping to the PTuning Race Header and JDL UQFP and will be retuning to account for the new cat and well as the flow differences between the UEL and EL.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
