Old 01-28-2015, 11:15 PM   #15
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by xkalelx View Post
^^ what he said.
This is a well engineered bushing REPLACEMENT of the OE front bushing ONLY. Will have to drop the differential to press out the OE bushing for replacement. Good option if you are going to see a lot of track time. I actually bought this with the insert pack and couldn't install without dropping center section.
Where is the OE front bushing on the differential. It's winter right now, and it may be several weeks (or more likely months) before I get my car up to look under it. Any chance you could find a picture to show me before then?
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 01-28-2015, 11:50 PM   #16
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
xkalelx is offline   Reply With Quote
Old 09-08-2016, 02:00 PM   #17
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
^^ what he said.
This is what I installed. They are inserts and utilize the OE bushings and fill in the voids to firm up how the OE bushing behaves. This is an economical option that is easy to install. Good for daily driving/ mild track. For front AND rear bushings of the differential.
This is a well engineered bushing REPLACEMENT of the OE rear bushing ONLY. Might have to drop the cross member to press out the OE bushing for replacement. Good option if you are going to see a lot of track time.
The inserts are great and well engineered. Start there and if you want more rigidness in the future, you can upgrade piece by piece. Hope this helps.
This post answered all my questions about the diff mounts, ILU SIR
Votlon is offline   Reply With Quote
The Following User Says Thank You to Votlon For This Useful Post:
xkalelx (09-08-2016)
Old 09-08-2016, 02:18 PM   #18
Thefear13
Thefear13's Avatar
Drives: Firestorm FT-86
I had the PBM Subframe/Diff bushing installed. Its a bit of work but I love it. It's noisy and you feel everything!
Thefear13 is offline   Reply With Quote
Old 09-08-2016, 02:43 PM   #19
Originally Posted by Koa View Post
Also don't forget that too stiff of a drivetrain can hurt the components in the system. ............. What are they trying to appease here- grocery getters and old mums?
Don't forget about old pops and running the grandchildren up to school ...... then getting the groceries ....
Personally, I haven't noticed any "slop" in the drivetrain of my MT FR-S.
Maybe, I'm just used to the old drivelines ...... where, if you couldn't rotate the driveshaft at least 1/4 turn ...... something was wrong .....
Old 09-26-2018, 02:44 PM   #20
ML
ML's Avatar
Drives: 13 White MT FR-S
Sorry to bring up this old thread, but my OE diff bushings are cracking and the rubber is separating around the bolts. What is the best diff mount option for that these days?
Old 04-04-2019, 02:10 PM   #21
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
anybody have an answer?
My OE bushings are also cracking and looking bad...
what's recommended
RickyRacer is offline   Reply With Quote
Old 04-18-2019, 11:14 AM   #22
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
what's recommended
If you're experiencing failure of the actual bushing, you need to replace them. The inserts are good only if your bushings are in good shape. Or get the diff brace. I'd still just replace the bushings, superpro makes a great set
Old 04-13-2020, 10:23 AM   #23
assbox
assbox's Avatar
Drives: Whiteout FRS
I have 99k miles on my car now. The differential bushings were cracked. I had installed the inserts(KDT925) for a week and then moved to the (KDT924) bushing replacement.
You can definitely get by on the diff inserts. But if you have a pretty beat up bushing you should just get the full replacements. KDT924 feels really good and worth the extra install time. I was able to do it without dropping the sub-frame or even removing my TRD exhaust.
IG: ft86carbon
assbox is offline   Reply With Quote
brace, bushing, drive train slop, mount, rear diff
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 03:43 AM
Rear diff LSD question Dephective Engine, Exhaust, Transmission 15 09-01-2013 05:30 PM
Rear Suspension Video (Look at diff bushings!) d1ck Tracking / Autocross / HPDE / Drifting 0 07-01-2013 10:02 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 10:23 PM
