Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: 86 GT
Stock PCV outlet - faulty/leaking?
Car has been boosted for a few years and heavily tracked. From turbo install, I had a mishimoto compact can connected between the crankcase breather (edit, thanks tomm.brz) outlet below the AC compressor and then returning to my intake between the air filter and turbo inlet.
Have noticed a lot of oil on top of the engine block, around this crankcase piece below the AC compressor and only on that side of the engine. I cleaned it up before last track day and the photos shown are from a days running basically so the PCV bit seems most likely point of leak to me? Nothing relating to the PCV valve or crankcase breather has been changed to my knowledge. Given boost, am I supposed to have changed something there? Could it leaking due to boost? Last edited by dave-; 04-08-2019 at 06:43 AM. Reason: clarified parts referenced! |
#2 |
Drives: brz 2017 hksv2
that s not the PCV, it s the crankcase side breather
Personally I would try putting a check valve in line of the real pcv, near battery, or directly swap it with wrx pcv (it costs few bucks) and see if it makes better the crankside |
The Following User Says Thank You to tomm.brz For This Useful Post: | dave- (04-08-2019) |
#3 |
Drives: 14 BSP Edelbrock BRZ
Seems silly to ask this but are you sure the hose on the breather isn't cracked or weeping?
The Following User Says Thank You to toast For This Useful Post: | dave- (04-11-2019) |
#4 |
Drives: 86 GT
#5 |
I'd check the hose first just so you don't get water or degreaser in any openings. I can't think of any other source for oil from that side of the motor.
The Following User Says Thank You to toast For This Useful Post: | dave- (04-16-2019) |
#6 |
Drives: 2017 PP BRZ
Where did you get the wrx pcv? I have been wanting to change mine! I am guessing the dealership?
#7 |
ypu can ask dealership or just get it online, it s cheap
code: 11810aa141 |
The Following User Says Thank You to tomm.brz For This Useful Post: | scion fr-s (04-15-2019) |
