Old 04-10-2019, 11:32 PM   #1
Youngmanhenry
Drives: Subaru BRZ
Anybody else ?
if so are there any fixes ?
Sent from my SM-G930T using Tapatalk
Youngmanhenry is offline   Reply With Quote
Old 04-11-2019, 12:36 AM   #2
TooSlow
Drives: Toyota
Still under warranty?
TooSlow is offline   Reply With Quote
Old 04-11-2019, 12:36 AM   #3
Brz_racer
Drives: Subaru BRZ
One or more of the plastic retainers looks like its not seated properly. Pull the panel back and give it a firm push in. Not too hard though you dont want to blow the airbag
Brz_racer is offline   Reply With Quote
Old 04-11-2019, 02:29 AM   #4
Have you been trying to run wires down behind it?
Mine used to do that. I finally figured out how to place and push it so that it stayed in place. How, sorry, I don't remember -
Old 04-11-2019, 02:46 AM   #5
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
weight reduction
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 04-11-2019, 03:24 AM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's totaled. Sorry.
Don't bother trying to sell it. You'll get maybe $50 with a bj on top. Maybe $100 for some booty play but who wants to deal with that?
Then there's option #2
It requires a bit of elbow grease, more like pull out the panel find the plastic clip. Either glue it or replace it.
Option #3
Drive car to dealership, cry about how your car is about to explode, tell them the dude on the internet says that it's going to set off the side airbags and the trajectory of that failed cover is going to cut your balls clean off.
Old 04-11-2019, 08:14 AM   #7
Youngmanhenry
Drives: Subaru BRZ
no sir
Old 04-11-2019, 08:15 AM   #8
Youngmanhenry
Drives: Subaru BRZ
Option #3
thx papa
Old 04-11-2019, 08:32 AM   #9
Mine did that but not quite as bad. I also had some rattling wires up in there. I just wiggled the wires around with a piece of coat hanger (battery disconnected!) heated the cover up with a blow drier (wife was pissed I used it) and gently pushed it back into place. Been there about 80.000 miles without issue now.
Old 04-11-2019, 01:20 PM   #10
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Doesn't the rubber door seal sit over the pillar cover, kind of holding it in place?
MJones_RB is offline   Reply With Quote
Old 04-11-2019, 02:01 PM   #11
Youngmanhenry
Drives: Subaru BRZ
yeah but im pretty sure a clip is fucked
Old 04-11-2019, 03:32 PM   #12
RickyBobby
Drives: 2013 Firestorm FR-S AT
I removed this panel to run the power wire behind it for my radar detector. The panel slips down into place and snaps in on the bottom and top. Pull the panel out on the top and make sure the top and bottom plastic fasteners are aligned and then snap it back in. This may help: http://www.ft86club.com/forums/showp...&postcount=101
Yes, the rubber seal sits over the panel and helps to hold it in place.
RickyBobby is offline   Reply With Quote
Old 04-11-2019, 05:16 PM   #13
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
As already established, your clip is either not seated properly or broken. I had a similar issue when running my dashcam and aftermarket HU microphone wire through that pillar and had to persuade the clip the seat properly.
If you need a replacement, I believe the part number for the upper clip is: 909150037
wolffbite is offline   Reply With Quote
