Drives: 2015 FR-S
Android head unit acting up
Cafi Dashlinq4 Android 4.4.1
It's been 100% and then all of a sudden last night this message below pops up and then the unit resets itself. "unfortunately, com.Cardroid.voice.update has stopped" I tried resetting to factory and going into apps and stopping and clearing data on the voice and voice.update apps and it just resets again after about a minute and repeats this over and over. Any ideas on what to do? |
#2 |
Drives: 86
I have the same issue and exact same problem that just started last night as well. Subscribed for a solution.
#3 |
Drives: 2015 FR-S
http://www.ft86club.com/forums/showp...postcount=2279
OK so this makes 3 of us in here and one other person on Android central. https://forums.androidcentral.com/as...s-stopped.html |
#4 |
Drives: 2015 FR-S
It seems like it's related to a certain date and time since everybody had it happen at the same time but when you reset to factory settings the time and date go back to 1960 something so we can't just change the date and time to fix it.
#5 |
Yikes, kitkat means its gonna be quite difficult to get a proper update for it to fix.
Is there a way to flash or sideload a different rom on this device? Like Lineage OS or something, just so you get a newer backbone and OS?
#6 |
Drives: 2015 FR-S
[ame]https://www.youtube.com/watch?v=xDVY3IoQTT4[/ame]
Here are some of the comments translated from Russian: Here is a setup from the manufacturer of car DEXP, the error is related to the calculation of the exact number of weeks through the exchange of data with GPS satellites, 0 April 6, 2019 was updated, and 0 7 no longer works. TEMPORARY SOLUTION, raise likes! We take out the radio and unscrew the back of the GPS antenna. Navigation, respectively, stops working, but the error disappears, the radio works fine. A similar situation ((. I couldn’t even find the firmware, I’ll take your word for it that the firmware will not help. I wonder what the solution will be? ***********OK so I got it running. You just have to kind of repeat what he did in the video. It was shutting off while trying it but in the end the date being set back one year and turning off those two check marks in GPS settings did it. If you go back into the GPS settings, they are checked every time so it seems like it rechecks itself after you exit that menu setting, not sure. I also unplugged the GPS satellite from the back too because I translated that in the comments below the video. So it's either the GPS setting, the date change or unplugging the antenna or some combination of that. The guy posting that replied it just needs the antenna to be unplugged. I didn't even use GPS in the car and I'd imagine most people don't either so I guess that's it I should also add that the unit on that video isn't a Cafi so this isn't just our units that were having an issue. There must be thousands of people out there with Android head units all having this issue all at once. Last edited by Impureclient; 04-08-2019 at 07:45 PM. |
#7 |
Drives: 2015 FR-S
Here is an explanation of what happened, it's global not just happening to users of this head unit:
https://www.energy.gov/oe/articles/a...umber-rollover |
#8 |
Drives: Asphalt Grey FR-S
I heard about the gps issue. Assumed a 2013+ device would have considered this. Anywho the apk name is so misleading i kept fiddling around with voice/sound/tts stuff...
2013 Asphalt Grey FR-S MT VIN: 7086XX
#9 | ||
Drives: 2015 FR-S
And the fix:
| Android head unit | drz400dude | Electronics | Audio | NAV | Infotainment | 6 | 12-20-2016 12:47 AM |
| 200mm android head unit with android lollipop | rsingh | Electronics | Audio | NAV | Infotainment | 3 | 05-23-2016 08:48 PM |
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| Ca-Fi dashlinq 4 Android head unit - $450 | chimmy | Audio/Visual, Electronics, Infotainment, NAV | 12 | 10-27-2014 12:14 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
