Old 03-17-2019, 05:09 PM   #85
Originally Posted by ermax View Post
Oh I see. Yeah that would be cool to see.
I realized that Crydo might get pestered about it so I removed his quote from my sig.
I hope that wasn't a problem, @Crydo. I understand your dilemma.
Old 03-17-2019, 05:50 PM   #86
entaroadum
Drives: 2013 Subaru BRZ
Yup, had been running perfectly. Just oil + filters. Then about 3 week ago cruising along at <3000 rpm: audible misfire, really rough idle then stalled. It cranked but did not start.
I got it towed home (it was already dark) then next morning found small oil poodle on the skid plate with what appeared to be some kind of roller bearing pins (probably from rocker arms). I then got it towed to the dealer as if it's recall related I might be getting a free new engine. If not then I'll rebuild it myself.
entaroadum is offline   Reply With Quote
Old 03-17-2019, 10:22 PM   #87
Sounds suspiciously like... It shouldn't take them three weeks to see if a valve spring broke.
Very interesting. How many miles on it?
Old 03-17-2019, 11:50 PM   #88
entaroadum
Well to be fair to them, 1 of those weeks was holidays here so they didn't work on those days. Then there's been a lot of back and forth because the car was originally not imported by them.
But they've finally agreed to check and take care of it IF it is indeed valve spring related.
Car has 42k miles
Old 03-18-2019, 12:25 AM   #89
Car has 42k miles
Keep us posted.
Old 03-18-2019, 02:03 AM   #90
Car has 42k miles
UGH! Sounds messy - good luck -
Old 03-18-2019, 10:08 PM   #91
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
... then next morning found small oil poodle on the skid plate....
That sounds bad, but at least it wasn't a large greased schnauzer on your tie rod....
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 04-01-2019, 11:38 AM   #92
entaroadum
Keep us posted.
It took a while but finally have a diagnosis. No spring failure, apparently rocker(s) ejected itself into the valve cover.
Should I be worried about this happening again after engine is fixed?
Album: https://imgur.com/a/a3PHSLO
Old 04-01-2019, 11:46 AM   #93
ermax
ermax's Avatar
I guess your image link was killed by the sensor.
Old 04-01-2019, 11:52 AM   #94
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Perfectly normal...
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 04-01-2019, 01:12 PM   #95
The procedure to replace that rocker involves all the same scraping and sealing that is done for this spring recall. If anything, that's what I'd sweat. :/
Tcoat (04-01-2019)
Old 04-05-2019, 05:06 PM   #96
JD001
JD001's Avatar
Drives: Subaru BRZ
Just received a recall letter... Quote "It has been found that the engine cylinder head valve springs may fracture, at worst case possibly causing the engine to stall.".
Old 04-05-2019, 07:01 PM   #97
OK, so - take it into a dealer and your local Bubba will "fix" it so it won't just "stall" anymore -
JD001 (04-06-2019)
Old 04-06-2019, 06:33 AM   #98
JD001
JD001's Avatar
Drives: Subaru BRZ
Humfrz, you'll be pleased to hear that my car is booked in for open heart surgery.. The service manager informed me that about 1000 spring kits have been allocated for the UK, covering BRZ/GT86, Forester, Impreza, Legacy/Outback and XV cars.
Has anyone taken the opportunity to switch the camshafts for something more interesting such as the HKS/Piper cams?
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (04-06-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Dealer recommendation for valve spring recall: South of Seattle rice_classic Northwest 8 03-17-2019 03:06 AM
VALVE SPRING WORLD - PRESS RECALL Trap63 Issues | Warranty | Recalls / TSB 85 03-12-2019 11:38 PM
67k miles, will bring car in for valve spring recall, what else to fix down there? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-19-2018 12:59 PM
Subaru Global Recall Checker (Japanese) - valve and so on Trap63 Issues | Warranty | Recalls / TSB 6 11-17-2018 03:28 AM
