#3039 |
Drives: 2017 Toyota 86
Found out what it was. I was watching a real time log today and saw the Delicious flex fuel content analyzer was rapidly toggling between 0-82% ethanol. During idle, the car's shuddering seemed to correlate. I then went back and looked at older logs on my computer and found an instance where a seemingly healthy sensor suddenly went dead. STFT immediately went to +35%. Measured AFR went to 19.99. All of this is consistent with the sensor reporting 0 ethanol content for E82. The ECU would think it has pure gasoline and for a commanded AFR of 14.7, the amount of "gas" (really E82) injected would be about 35% less than required to get a lambda of 1 on E82.
#3040 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#3041 | |
https://www.delicioustuning.com/site...Parameters.JPG |
| The Following User Says Thank You to Mr_Eyo For This Useful Post: | BirdTRD (04-08-2019) |
#3042 | |
#3043 | |
Car Goes Bang
Drives: 2013 FRS, 2014 BRZ
What makes me think you are onto something with the ETOH sensor is that this problem started when I switched over. I assumed the actuator leak was then the issue but it was only one of at least two issues. I updated the ProECU software and I now see the ETOH %. - many thanks BTW I went with IP ignition direct coils which should help with weak spark. Last edited by Bunsin; 04-05-2019 at 09:35 PM. Reason: Updated software to get ETOH% |
#3044 |
Thread Lurker
Drives: 2015 Edelbrock BRZ
I have a question about fitment between the grams 72mm throttle body and the edelbrock SC. I've been told its possible for them to work nicely together however there is some modding required. anyone have experience with these two things?
#3045 |
You'll want to stick to the OEM throttle body. YOu can stretch the Edelbrock hose if you really want to.
#3046 |
Thread Lurker
At this point the OEM throttle body is a restriction. Needing a bigger one. However, I ordered the grams 72mm and didn't read that it was not recommended for edelbrock due to it not being a straight bolt on. you have to mod the inlet tube for it to fit.
also, is there a good thread to read up on good internals? I heard manley pistons and rods were good but they lower the compression ratio and I want to keep the compression the same. |
#3047 | |
Simply Forgotus
#3048 |
Drives: 13 BRZ, 07 WRX
Bought the Supercharger and ordered the ECUTech and tune for delicious. Looking forward to starting the install soonish.
Lucked out and my kit was made this year. It has the V2 surge tank and I hope it has the fixed actuator. I called Edelbrock to ask about what has changed in the kit over the last few years and they had no idea....
13 BRZ Premium. 07 WRX.
#3049 | |
#3050 | |
PhoneFlash by EcuTeK
As Mike @ CSG has stated the stock throttle body works rather well and we have tuned cars well over 500+ hp with the OEM piece. Cheers, William Knose Master Tuner @ Delicious Tuning |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | shr133 (04-28-2019) |
#3051 | |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | CallmeDave (05-20-2019) |
#3052 | |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | BirdTRD (04-09-2019) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
