#99 | |
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
@Ashikabi wanted to mention this since I saw an issue in @spitsnaugle build and looks like you may run into the same problem with the way your spark plug wires are currently routed.
Tough to tell without seeing how all yours were routed but figured I'd mention it to save you some heartache in the future if they were routed the same as his first attempt. |
| The Following User Says Thank You to Axis2011KR For This Useful Post: | Ashikabi (12-18-2018) |
#100 | |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Axis2011KR (12-18-2018) |
#101 |
Got out into the garage again. Gonna work on mounting the transmission again even though I'll gave to take it back out anyways. I was trying to avoid this but it's better than nothing.
Anyways, I installed the Cusco differential brace and changed the fittings on my Racer X dual catch can to work with the LS1. I got most of the way done with installing Whiteline subframe bushing inserts. Last subframe mount bolt said"fuck you" and cross threaded. I ordered a tap to clean up the threads in the frame, should be finished next weekend. ![]() ![]()
| The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | Leonardo (03-18-2019), Sportsguy83 (03-17-2019) |
#102 | |
I Love custom Turbo kits
Drives: Limited BRZ
This happened to me to on the front passenger bolt. The tap worked like a charm. Good luck looking good!
#103 |
Thanks. I still can't get it running but I suppose I can get the transmission mounted. I was trying to avoid putting it in and taking it out needlessly but it's better than doing nothing
| The Following User Says Thank You to Ashikabi For This Useful Post: | Sportsguy83 (03-17-2019) |
#104 |
I started mounting the transmission today. Cut out for the MGW shortshifter. Sprayed everything with underbody spray. Installed speed bleeders and installed the RivNuts for my fuck up fix strut tower to firewall bar. Pretty far from ideal but better than nothing.
#105 |
Mounting transmission and drive shaft. Transmission sits tail down at about 4.5 degrees
Driveshaft is tail down at about 2.5 degrees Diff is nose up (tail down) at 1 degree This somewhat close to being right? The calculator I was using wasn't 100% clear on which way things were tilted with their sliders |
#106 |
Drilling to mount the transmission crossmember now. I cut out the offending transmission tunnel bracing to make room for the transmission. I'm seeing now that doing so was a mistake. My mounts are on the edge of the bracing which will make them sit weird and it's very hard to drill here. I definitely suggest removing the bracing (lower rear at the very least) when cleancing the tunnel. The bracing across the top of the tunnel seems fine but if it was also removed, I would have more room for my drill, since the transmission is in the car and I'm working around it.
The white in the picture is where I scraped off the factory seam sealant to give my mounts a more solid surface to bolt to ![]() UPDATE: remove all bracing. Just do it. Last edited by Ashikabi; 08-05-2019 at 09:57 PM. |
#107 |
Mounted transmission and MGW short shifter
| The Following User Says Thank You to Ashikabi For This Useful Post: | ILLSMOQ (03-30-2019) |
#108 | |
Drives: 2017 WR BLUE BRZ
#109 |
Notes on the MGW shifter: it moves the shift knob forward about an inch/ inch and a half... The TR6060 seems to move the shifter back about the same. As such I think this combination puts the shift knob almost exactly where it was with the FA20. I did have to cut about 1/2-3/4 inches off the rear of the shifter hole. If you want to use the rubber boot that comes with it I suggest cutting the sides of the shifter hole back about 1/4 inch PER SIDE. I didn't do this and the boot sits kinda bulgy and it was a pain to get installed to begin with. Otherwise, I'm very happy with this shifter. Feels good. Nice short crisp movements. FYI, if you need the pin that attaches the shift lever to the arm on the transmission, you'll need a 12mm clevis pin with just over an inch throat. Measure your arm to be sure on length
#110 |
Got most of my interior back in. Shifter ended up being pretty close to identical for stock position. The switch to activate my Accusump had to be modified to clear the shifter bezel. Cut off the tip of the cover and added a side pin to flip open.
Driver valve cover interfered with my master cylinder. If you are using an LS1 I suggest you try to use some other method of mounting the master cylinder. Whether that involves making a pocket like @spitsnaugle did or finding some other method. Anyways, we ground into valve cover until it (barely) cleared the banjo bolt. If course we broke through so I added some JB weld to seal it up. I'm not happy with how this worked out but I don't really have any practical ideas to change it. Got my radiator shroud done too. I've spent WAY too much money on this so I went cheap... Got a big cookie sheet on eBay and cut it up LOL. Cheapest you'll find large pieces of aluminum sheet. Hammered the bends in it, rattle can, some foam weather strip insulation on the edges and self tappers to hold it on the radiator flange ![]() ![]() ![]()
#111 | |
Drives: LS Swapped Scion FRS = 440HP
#112 | |
I have concerns about the angle of your master cylinder. I'd like to steer away from that if possible, no offense intended and I could be wrong. I believe (haven't checked for certain) that my master cylinder sits at a slight angle whereas IIRC yours sits perpendicular to the firewall. Though I suppose if you carefully located it vertically to bisect the vertical travel of actuation rod you would pretty well negate any negative effects |
