Old 04-02-2019, 03:16 PM   #15
Turbo
Drives: FR-S Turbo
If you are worried about brake dust.....
Maybe you shouldn't be on a race track.
Maybe you should park hard bro!
You know like those car circle jerk parties all over instagram.
It isn't about the look of brake dust, sparky - it's that when you run real race pads the "brake dust" is corrosive as hell.
Turbo is offline   Reply With Quote
Old 04-02-2019, 03:18 PM   #16
Turbo
Drives: FR-S Turbo
Thanks, guys-
Plastidip it is!!
Next question:
Color suggestions for the rims to go with a car that's Asphalt with carbon bits?
I was thinking bronze or copper....but am open to other ideas!
Old 04-02-2019, 03:37 PM   #17
FirstWinter
Drives: Car
Originally Posted by Turbo View Post
Thanks, guys-
Plastidip it is!!
Next question:
Neon Green
FirstWinter is offline   Reply With Quote
The Following 2 Users Say Thank You to FirstWinter For This Useful Post:
kch (04-02-2019), strat61caster (04-02-2019)
Old 04-02-2019, 04:33 PM   #18
wparsons
wparsons's Avatar
Not all real race pads have corrosive dust... just certain compounds/brands.
flickr
Turbo (04-02-2019)
Old 04-02-2019, 04:49 PM   #19
ka-t_240
Originally Posted by 15limited View Post
How many wheels have you seen fail? What brand of wheels? I'll believe it, if you told me you had proof lower quality flow formed wheels and the electromagnetic process of powdercoating weakened them, but all you just said powdercoated wheels are weaker...
Sent from my SM-G950U using Tapatalk
It could be an age issue, a coating issue, a bad wheel issue, don't know. They were all items that had been blasted and coated a different color.
~7-8 individual wheels that i have personally seen in recent memory. Some were minor cracks that were caught before major issue. 2 Rota, Couple of Enkei, and I believe a Gram Light.
ka-t_240 is offline   Reply With Quote
Old 04-02-2019, 06:12 PM   #20
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Thanks, guys-
Plastidip it is!!
Next question:
Dark silver wheels are my suggestion, using a black base, with silver metalizer. Even with full coverage the color is still nice and dark. The main reason I suggest that over gold, is that you can apply touch up coats if the color ever discolors due to dust etching into the dip.
I've also done bronze, but it eventually turned to full gold for the same reason I mentioned above. I'd apply more metalizer to freshen the finish which brightens the color, rather than strip and reapply from a bare wheel.
If you're okay stripping and reapplying from scratch to maintain the finish you want, then disregard what I said.
The Following User Says Thank You to RToyo86 For This Useful Post:
Turbo (04-02-2019)
Old 04-02-2019, 06:31 PM   #21
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks, guys-
Plastidip it is!!
Next question:
I think the bronze would look great on your car.
https://www.ft86club.com/forums/show...25&postcount=4
The Following User Says Thank You to new2subaru For This Useful Post:
Turbo (04-02-2019)
Old 04-02-2019, 07:30 PM   #22
15limited
15limited's Avatar
I would immediately assume its wheel construction material and/or powdercoating process issue.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 04-02-2019, 10:55 PM   #23
Turbo
Drives: FR-S Turbo
Thanks for the tips!
The wheels themselves are flat black from the factory with bare aluminum machined recesses. I'm toying with the idea of trying one with silver or copper metalizer just over the factory black?
Could be a neat look with the bare machined areas adding some contrast.
These are the rims I'm running:
Old 04-02-2019, 10:56 PM   #24
Turbo
Drives: FR-S Turbo
Me too!
Thanks for the pics, Glenn!!
Old 04-03-2019, 05:53 AM   #25
RToyo86
RToyo86's Avatar
You need the black base dip to build up layers and also provide something for the metalizer to stick to. Metalizer/pearls are much more fluid than standard plastidip.
One can per wheel, at least 3 cans for all four wheels. Any less and it'll be a nightmare to peel off later.
Turbo (04-03-2019)
Old 04-03-2019, 07:25 PM   #26
Turbo
Drives: FR-S Turbo
Thank you again for all your help!!
Plasti-Dipped Wheels hobojoker Cosmetic Modification (Interior/Exterior/Lighting) 274 07-24-2015 10:02 AM
Plasti Dipped Gold Wheels Khalis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 72 07-10-2014 12:37 PM
How to Plasti Dip Wheels! (Video) Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 07-07-2014 05:51 PM
Plasti-dip wheels (Anthracite) jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 6 08-30-2013 05:44 PM
plasti dip wheels and the track? subaruferrucci Tracking / Autocross / HPDE / Drifting 17 05-17-2013 01:36 AM
