Old 04-01-2019, 07:06 PM   #15
bravedeer
Drives: Subaru BRZ 2013 Limited Manual
Originally Posted by DandoX View Post
True, but any '13 that's driving around now with a decent mileage is probably okay. However judging the overall reliability on the '13 vs other years I dont think there is that much a difference.
I do think that the quality control on the '13s is not as consistent vs other years. Some 13's just seem to have issues vs mine which has been great for about 6 years and over 80k with no problems (except TOB). If a '13 is over 50k I'd wager it is probably just as reliable over its total life as any other year.
Both 13's I've owned had the wiring harness/coil issue. It's actually a flawed design so I feel bad for anyone who didn't do it under warranty . . .
bravedeer is offline   Reply With Quote
Old 04-01-2019, 07:10 PM   #16
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Im not familiar with that issue, just did a bit of research. Strange mine has been fine and never had an issue. Does this only happen at the track?
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
humfrz (04-01-2019)
Old 04-01-2019, 07:30 PM   #17
bravedeer
I've never tracked my cars. It starts with issues starting the car where it'll start and then die. If it does happen to you at some point, make sure they put on a new wiring harness and not just the same old design coils, or it'll happen again.
The Following User Says Thank You to bravedeer For This Useful Post:
DandoX (04-01-2019)
Old 04-01-2019, 07:32 PM   #18
I've often suspicioned that most of the 2013 cars that have had problems have engines that were messed with and or were tracked -
DandoX (04-01-2019)
Old 04-01-2019, 07:36 PM   #19
DandoX
Senior gif poster
DandoX's Avatar
I think you may be right, because my car has never once failed to start on the first go in 6 years.
Old 04-01-2019, 07:40 PM   #20
Same here. Six years, no CELs nor any other problems. - maybe we just got cars that were "blessed" -
Old 04-01-2019, 07:45 PM   #21
DandoX
Senior gif poster
DandoX's Avatar
I think we may have 'tuesday cars' as it has been put by @TheRacersLine
humfrz (04-01-2019)
Old 04-01-2019, 10:05 PM   #22
ermax
ermax's Avatar
The coil pack problem is mostly related to heat. If it you’re up north and never track the car then you are probably fine.
As for 50k being in the clear. Mine was at 83k miles when #3 went and the other three had brass coming through so they wouldn’t have been far behind. I think the previous owner just didn’t drive the car hard enough to have oil pressure issues. It probably never saw redline before I owned it. Under my ownership it sees redline a hand full of times a day. I also autox it. I suspect that if I owned the car from day one it would have gone much sooner. There were no signs of bolts being removed anywhere on the car and no other evidence of mods. The CD player came with a B52s CD in it if that tells you anything. Hahaha
Before anyone calls my driving abuse, I’ve run previous cars much harder than my FRS and didn’t have bearing failures. My old Integra GR-R was autoxed every month for about 4 years and saw redline anytime the roads were open. The only real issues I hard were syncros and pressure plates flying apart because I regularly flat shifted. I was young and drove like a retard. I did end up hydrolocking it in a flood and after that it was down hill with a spun bearing a year later year then 6 months later and then 2 months later. It also started burning oil due to the water damage to the cylinder walls which were still there even after boring to the service limit and running oversized pistons.
2016 OEM Head Unit in a 2014 AnotherSlowAE86 Electronics | Audio | NAV | Infotainment 0 08-14-2018 07:13 PM
WTB: 2014-2016 BRZ CWP (SoCal) icecord Want-To-Buy Requests 2 06-30-2016 06:09 PM
WTB 2014-2016 SWP BRZ Limited - SoCal icecord Want-To-Buy Requests 5 06-07-2016 03:39 PM
2016 FR-S vs 2014 WRX Hatchback SosaR FR-S / BRZ vs.... 47 05-05-2016 01:53 PM
Do the 2013 and 2014 FRS models have the same engines? Turbo_FRS Scion FR-S / Toyota 86 GT86 General Forum 83 12-15-2013 11:36 PM
