#85 |
I realized that Crydo might get pestered about it so I removed his quote from my sig.
I hope that wasn't a problem, @Crydo. I understand your dilemma.
#86 |
Drives: 2013 Subaru BRZ
Yup, had been running perfectly. Just oil + filters. Then about 3 week ago cruising along at <3000 rpm: audible misfire, really rough idle then stalled. It cranked but did not start.
I got it towed home (it was already dark) then next morning found small oil poodle on the skid plate with what appeared to be some kind of roller bearing pins (probably from rocker arms). I then got it towed to the dealer as if it's recall related I might be getting a free new engine. If not then I'll rebuild it myself. |
#87 | |
Very interesting. How many miles on it?
#88 | |
But they've finally agreed to check and take care of it IF it is indeed valve spring related. Car has 42k miles |
#89 |
#90 | |
![]() humfrz |
#91 | |
Feeling like thinking....
![]() Quote:
That sounds bad, but at least it wasn't a large greased schnauzer on your tie rod....
Drive like everyone's life around you depends on it...
#92 |
It took a while but finally have a diagnosis. No spring failure, apparently rocker(s) ejected itself into the valve cover.
Should I be worried about this happening again after engine is fixed? Album: https://imgur.com/a/a3PHSLO ![]() ![]() ![]()
#93 |
I guess your image link was killed by the sensor.
#94 | |
Drives: 13 Subaru BRZ
Sent from my PH-1 using Tapatalk |
#95 |
The procedure to replace that rocker involves all the same scraping and sealing that is done for this spring recall. If anything, that's what I'd sweat. :/
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (04-01-2019) |
#96 |
Drives: Subaru BRZ
Just received a recall letter... Quote "It has been found that the engine cylinder head valve springs may fracture, at worst case possibly causing the engine to stall.".
#97 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | JD001 (04-06-2019) |
#98 | |
Drives: Subaru BRZ
Has anyone taken the opportunity to switch the camshafts for something more interesting such as the HKS/Piper cams? Last edited by JD001; 04-06-2019 at 08:04 AM. |
| The Following User Says Thank You to JD001 For This Useful Post: | humfrz (04-06-2019) |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Dealer recommendation for valve spring recall: South of Seattle | rice_classic | Northwest | 8 | 03-17-2019 03:06 AM |
| VALVE SPRING WORLD - PRESS RECALL | Trap63 | Issues | Warranty | Recalls / TSB | 85 | 03-12-2019 11:38 PM |
| 67k miles, will bring car in for valve spring recall, what else to fix down there? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 12-19-2018 12:59 PM |
| Subaru Global Recall Checker (Japanese) - valve and so on | Trap63 | Issues | Warranty | Recalls / TSB | 6 | 11-17-2018 03:28 AM |
