Northern California NorCal
Old 03-16-2019, 01:28 PM   #57
hellyvin
Drives: WRB Brz
No experience at Stevens Creek but just dropped my car off at Premier Subaru in Fremont. As others had already mentioned, dropped in with no appointment and got a Hertz Rental. The service advisory said the car might be ready by next Wednesday or Thursday. I dropped it off Thursday. They said there are 3 techs working on just that issue.
Will update when I get the car back.
hellyvin is offline   Reply With Quote
Old 03-18-2019, 01:47 PM   #58
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Saw this in another thread. Also had it semi-confirmed by a friend of a friend who works at DMV. Anyone else that can be more confirmation then that?
I renewed my registration last week no issue.
It won't come up until the car needs to go in for smog certification and it will fail the smog check because of a note in the system. For 2013 cars the earliest that will happen is April of 2020. And even then, lots of empty threats and little follow through because shits expensive yo.
strat61caster (03-18-2019)
Old 03-19-2019, 12:14 AM   #59
MyRx
MyRx's Avatar
Not going to great details but we just lost another one recently. The owner had the recall done in Feb and rarely drove it since, until last week. His clue of something gone wrong was a pop in the motor. He immediately pulled over and that was it. Engine is on fire.
Moral of the story, you hear or feel something wrong, pull over immediately!
Old 03-19-2019, 01:52 PM   #60
finch1750
finch1750's Avatar
Damn. This is a little too common. Think it makes 2 or 3 now?
Old 03-21-2019, 09:38 PM   #61
hellyvin
Drives: WRB Brz
Update. Picked the car up this morning. Got home which is about 6 miles from the dealership and knocking sounds appear with engine light blinking. Car dies while trying to idling. Called the dealer (Premier Subaru in Fremont) and had the car towed back. They gave me another loaner while I wait to hear from them about what they find...
The Following User Says Thank You to hellyvin For This Useful Post:
Thaeyo (03-22-2019)
Old 03-24-2019, 07:58 PM   #62
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Oh wow, blinking CEL usually means misfire... not good at all.
tigermack is offline   Reply With Quote
Old 03-24-2019, 08:28 PM   #63
hellyvin
Drives: WRB Brz
They checked the car and are now saying it has something to do with the engine harness. Service advisor said the tech found that when he wiggled one of them the engine will cut off at idle... does that sound legit?
To me it seems to me there’s a knocking sound come from the engine but I’m not expert.
Old 03-24-2019, 11:07 PM   #64
Twin#2
Twin#2's Avatar
Drives: 13 BRZ Limited, 16 Tacoma, 01Celica
I just had mine done at Modesto Subaru this past week and had them change my spark plugs, clutch and flywheel . I got my car back on Wednesday afternoon and drove it home thinking all was good. Now every time I start the car there is either a rattle/ grinding coming from either the engine or transmission and it is very noticeable.
I have an appointment this Tuesday for them to check it but I'm not gonna drive it until then in risk of breaking something.
Twin#2 is offline   Reply With Quote
Old 03-27-2019, 11:46 AM   #65
uEih
Drives: CBS Subaru BRZ Limited
I've been out of the loop, what qualifies you for the fix and how do I know to bring it in? 2013 Subaru here and my engine doesn't die randomly or anything weird. I just had my throwout bearing replaced and that put a real ding in my wallet. I hope they do something about that also.
uEih is offline   Reply With Quote
Old 03-27-2019, 12:15 PM   #66
driggity
Drives: Silver Coupe with a Boxer
Check your VIN here:
https://www.subaru.com/vehicle-recalls.html
I don't think you'll get any signs of the issue before it fails so you would want to get it down ASAP.
driggity is offline   Reply With Quote
The Following User Says Thank You to driggity For This Useful Post:
uEih (03-27-2019)
Old 03-27-2019, 12:15 PM   #67
finch1750
finch1750's Avatar
You should have got a letter. Otherwise call your local Subaru service department and ask them to check your VIN and see if you are part of the recall
uEih (03-27-2019)
Old 03-27-2019, 12:35 PM   #68
uEih
Thanks, my car is affected and I scheduled an appointment... now I'm regretting bringing in the car to fix my throwout bearing at a mechanic. I'm curious if they would've gave me a deal if I brought this in with the throwout bearing issue and recall.
Old 03-27-2019, 02:32 PM   #69
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
You would have saved on labor costs.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 03-29-2019, 02:37 PM   #70
uEih
Boo, that's too bad. Sounds like I could've saved ~$600-700 and that would've went to my tires. Having big regrets now, literally a week from fixing my throwout bearing too.
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 01:10 AM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
Valve Spring Recall Dealers AsianStyle Mid-Atlantic 20 05-04-2019 03:43 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 09:44 PM
