Old 03-27-2019, 11:01 PM   #17599
maslin
Benz Tech
Drives: 2017 BRZ Premium
Today my wife drove my BRZ to work. Because the m’fing pack rat is back and took out her perfect ‘17 Tacoma we bought new.
Grabbed a ScanGauge II on the way home from work (conveniently), and went at it. Fault code p21D4. Nothing on the internet, found a Ford document that says injector 6 open circuit, I can work with that.
Pull the intake, harness is chewed clean though at the connector. Injectors are on a sub harness I would be happy to replace, but they can’t be unplugged with the rail on. Jerks.
Fixing time. Might need supplies
So, after today the BRZ will have some additional gauges thanks to this $150 situation.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Tcoat (03-28-2019)
Old 03-28-2019, 10:41 AM   #17600
Why do rodents always seem to chew the most random spots possible? Like, why way up there? I would love to know what is going through their little rat brains.
Old 03-28-2019, 10:55 AM   #17601
maslin
Benz Tech
Those two wires are missing a solid 1”. The 4 next to them are untouched. The only other damage I can find is a mangled ground clear on the other side under the power steering pump.
The BRZ was under the booster. Meanwhile, my ‘83 Toyota 4x4 is sitting 10’ away and hasn’t been invaded. Too many carcinogens in the wiring probably
The Following 2 Users Say Thank You to maslin For This Useful Post:
norcalpb (03-28-2019), Tcoat (03-28-2019)
Old 03-28-2019, 11:21 AM   #17602
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
You probably already know this but...
"A class-action lawsuit was filed in 2016 in California against Toyota claiming the company should cover — under warranty — damage from rodents chewing through insulation for wiring that is now soy-based versus petroleum-based."
https://www.freep.com/story/news/loc...les/578398002/
You should think about doing some of the things mentioned in the article or as others on here have done.
Put my mouth around his head,
Closed my jaw and now he's dead
The Following User Says Thank You to Stephen W. For This Useful Post:
Dadhawk (03-28-2019)
Old 03-28-2019, 11:43 AM   #17603
maslin
Benz Tech
I've got the cat covered, poison traps, herbal things, cayenne spray, etc. I'll look in to it a bit more. Wish I could park in the garage, it's more of the kids lounge/RC shop/climbing wall/bike shop these days.
I did figure out what the cubby under the climate control is for, fits a ScanGauge II perfectly
Old 03-29-2019, 02:14 AM   #17604
Chuckls
Moutain Runner
Installed some catless noisy bois
Chuckls is offline   Reply With Quote
Old 03-29-2019, 04:49 AM   #17605
Seiryuu
Drives: ZC6
It was a beautiful and warm sunny day here so I finally washed my car in I think over six months... then it started raining out of nowhere in the evening. All that effort wasted...
The damn weather forecast said it was supposed to be sunny all the way until next week!
FML
Seiryuu is offline   Reply With Quote
Old 03-29-2019, 07:26 AM   #17606
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Originally Posted by wolffbite View Post
I took time off for an extended 4 day weekend and did some detail therapy in preparation for spring/summer.
Here is the condensed version of what I did:
Full wash with high pH soap
Claybar
Iron-X decontamination
1-step polishing
1 Coat Jescar Powerlock+
2 Coats Collinite 845 wax
CarPro Flyby Forte to windshield
Full interior clean/detail
Switch back to summer wheels/tires
After about a week it will get it washed again and then topped with P&S Beadmaker for a final protective layer.
All in all about 20 hours start to finish. Not perfect by any means, but I learned a lot for next time and it looks amazing in the sun! Pictures do not do it justice.
You wouldn't happen to follow Obsessed Garage? Car looks great! I have been wanting to get some Beadmaker to try.
derekbrz24 is offline   Reply With Quote
Old 03-29-2019, 11:50 AM   #17607
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Thank you!
Yes I follow Matt and several other detailers on youtube. I can only dream of one day having the garage setup and cars he has.
It ended up raining on Tuesday so I rewashed on Wednesday and applied beadmaker. Pretty amazing slickness on the paint, looking forward to see how it holds up. Seems to work quite well as a drying aid. Glad I bought a gallon though as I used up almost a full 16oz sprayer bottle for the first coat.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
derekbrz24 (04-01-2019)
Old 03-29-2019, 02:18 PM   #17608
Victorscp
Drives: 2018 BRZ premium
drove the car to work today still think the dip is way over rated... but i have a 2018 brz
Victorscp is offline   Reply With Quote
Old 03-29-2019, 08:27 PM   #17609
mrg666
pessimistic skeptic
mrg666's Avatar
You are probably downshifting properly. Try to accelerate at 5th without downshifting and enjoy the dip. You are welcome
Old 03-29-2019, 09:00 PM   #17610
Carlos.z
Drives: Limited brz
Swap
Carlos.z is offline   Reply With Quote
The Following 5 Users Say Thank You to Carlos.z For This Useful Post:
Drakiv (03-30-2019), jello4018 (03-31-2019), korhun (06-09-2019), MJones_RB (04-01-2019), spike021 (03-31-2019)
Old 03-30-2019, 11:30 AM   #17611
ghst86
Drives: 2016 BRZ Limited
I use beadmaker as a topper to my existing sealant, and it's absolutely mind blowing how well it works. I've tried a lot of other products, but this one wins, hands down.
Just gotta throw it on once a month and you're set.
ghst86 is offline   Reply With Quote
Old 03-30-2019, 03:37 PM   #17612
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Then again, most NA 4 cylinders do not have much to give when you floor the accelerator in a high gear/low RPM situation.
NCtoBRZ is offline   Reply With Quote
