go_a_way1
Old 02-12-2019, 02:50 AM   #4845
jflogerzi
jflogerzi's Avatar
@CSG Mike
I am preparing my car for its first event during the next round of 86 cup. I will be adding a Sprintex 210 supercharger plus intercooler(Scored a really good deal on it) Currently have the OEM+ Oil cooler with my NA setup and I know it will not cut it for track duty. Not to have to deal with high IAT or weird placements of an oil cooler, would the Jackson Racing Dual Radiator be a better choice and can it handle the heat the SC will put out with a 10 PSI pulley?
Or would this be enough in the Fog Lamp Area
MAP Oil Cooler
Everything else will be set with better pads and high temp brake fluid.
2013 Series 10 FRS #553
Old 02-12-2019, 12:37 PM   #4846
juliog
juliog's Avatar
Drives: 86
The Sprintex isn't track worthy, even with the optional heat exchanger. It will heatsoak really bad and there's nothing you can do about it, as the overall design is flawed.
If you're going to track the car, get rid of the kit.
juliog is offline   Reply With Quote
Old 02-12-2019, 02:28 PM   #4847
jflogerzi
jflogerzi's Avatar
Well I am not a hardcore track rat, just the occasional hpde.. this is mostly a DD and canyon/fun driver with flex fuel.
Sent from my ONEPLUS A5010 using Tapatalk
Old 02-12-2019, 02:55 PM   #4848
juliog
juliog's Avatar
Drives: 86
That's fine . Just warning you before you dump a lot of money on cooling parts trying to address an issue that can't be fixed, short of giving up on running that particular SC on track.
With an otherwise stock car, you'd just want:
- Oil cooler (Jackson Racing, Greddy...). The "OEM like" oil-to-water heat exchangers will be OK for maybe your first couple track days on a 6MT, no more. On an auto car they won't cut it at all.
- Brake fluid (PMU GFour, Endless, Brembo HTC, Castrol SRF..)
- Brake pads (PMU CR, Winmax W5/W6, Carbotech/GLoc XP10.. or CSG Spec brake pads ofc)
- Front camber bolts
The Following 4 Users Say Thank You to juliog For This Useful Post:
mixxxx (02-12-2019), Shark_Bait88 (02-13-2019), TRAKRAVN (02-12-2019), treedodger (02-18-2019)
Old 02-16-2019, 05:07 PM   #4849
jflogerzi
jflogerzi's Avatar
I have decided on the Jackson racing dual radiator. Simple and effective. I already bought the supercharger so no going back. If it heat soaks at the track then so be it. Track time will make up a small precentage of my driving. Thanks for the warning.
The Following User Says Thank You to jflogerzi For This Useful Post:
juliog (02-17-2019)
Old 02-27-2019, 10:05 PM   #4850
Windycity
Drives: 2013 Scion frs
i have a similar question: I have a 2013 6MT. My upgrades so far are FT86 Header, TRD catback exhaust, OFT with the Stage 2 E85 tune, and 5ad 19" x 8.5 and 19x9.5 wheels with Pirelli Tires. Will my wheel and tire setup be ok for the track? I plan on getting an oil cooler, new brake pads and brake fluid before hand.
Windycity is offline   Reply With Quote
Old 03-01-2019, 04:08 PM   #4851
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
You'll be fine, but I'd recommend getting a smaller wheel/tire package if you're gonna start tracking more often. 19's look good on the street but really hurt gearing and acceleration. For non boosted power levels, a lot of people go 17x8 with a tire size that gets them to about stock wheel/tire diameter. The classic Enkei RPF1's with some budget Hankook RS4's are something to look into without breaking the bank.
JCW 86 is offline   Reply With Quote
The Following User Says Thank You to JCW 86 For This Useful Post:
Racecomp Engineering (03-04-2019)
Old 03-01-2019, 05:14 PM   #4852
kch
Senior Misanthrope
kch's Avatar
Like said above, they'll be "okay" as in they won't kill you. But they'll hold you back for sure, and I shudder to think of prices for 19" tires.
Find an inexpensive set of lightweight 17x8 or 17x9 wheels and throw some 225/45 or 245/40 tires on them.
The Following User Says Thank You to kch For This Useful Post:
Old 03-04-2019, 12:48 PM   #4853
CSG Mike
CSG Mike's Avatar
Wheels and tires will be okay, but 19" with super skinny tires are more prone to damage from offs than a 17" or 18" with larger sidewalls.
Old 03-10-2019, 12:10 PM   #4854
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Ill be installing some Koni yellows with a swift r springs (I believe they are close to 5k front and 6k rear) and the topic of bumpstops came up. I found this site with a few options>
https://www.resuspension.com/index.p...ot-series.html
This car I am striving to build is a budget autox/trackday/'daily' that will round out all three. aiming to stay in or around STX, and T4 for SCCA and NASA, as well as show aspiring individuals that for not very much you can have a highly tuned and fun machine.
The rest of the suspension is whiteline swaybar and endlinks, kumho V720 tires and stock control arms and spl camber bolts.
My gut tells me to run a shorter but stiff front bumpstop and a longer but softer rear. to allow front nose transitions in chicanes and slaloms but give the rear end a chance to squat and settle without oversteer concerns.
Clutch Dog is offline   Reply With Quote
Old 03-29-2019, 01:01 AM   #4855
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Not sure if it fits in this thread but I just did my first Novice Autocross and would like to see what class I'm in.
My local club has a rule if you do 3 novices groups or win novice you gotta go to your class. I posted on their forum about classification but no one has answered me for days now.
Their classification is:
Uses the SCCA's car classing scheme and the portion of their rules that deals with car classing
the only exception is they have Adoption of our old SMST classes.
I think they have SMST and SMST2.
2013 FR-S
Mods I have are:
Wheels 17x8 +35
Tires 225/45/17
2017+ OEM CF Wing
Lip Kit
Catback Exhaust
Clueless
YamahaR86 is offline   Reply With Quote
Old 03-29-2019, 01:24 AM   #4856
Chuckls
Moutain Runner
2013 FR-S
Mods I have are:
Wheels 17x8 +35
Tires 225/45/17
2017+ OEM CF Wing
Lip Kit
Catback Exhaust
Check out the FB group "Autocross buddies". Much better than the local orlando group.
Chuckls is offline   Reply With Quote
Old 03-29-2019, 09:16 AM   #4857
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
I don't really have FB, I went to MartinSCC and know there is a SCCA around here that's about it.
Clueless
Old 03-29-2019, 12:44 PM   #4858
Molez93
Scott M
Molez93's Avatar
Drives: '13 BRZ (DocWalt's old car)
https://cny-scca.com/solo/rules.php
Old data, but decent for starters I hope.
Go to Classing Guidelines in the middle of the 2nd paragraph.
This is just a summarized list, but it sounds like more than you've found so far. The safest bet is to read the complete SCCA rule set.
The wing and lip sound like they bounce you far from where your actual performance will be. You're not street (aka stock) and even Street Touring doesn't allow for wings and spliters unless they were available from the dealer/Toyota as common options from a non-TRD catalog for that year. Best guess is C Street Prepared, but don't quote me on that.
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240
06 BMW Z4M Roadster, 20 M850
Molez93 is offline   Reply With Quote
The Following User Says Thank You to Molez93 For This Useful Post:
YamahaR86 (03-29-2019)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
