| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2013 FRS, Asphalt
Lowering springs vs coilover vs clearance
So I picked up some Option Lab R716 18x9.5 +35 without realizing these rub unless you have coilovers installed, coilovers are not really in the budget at the moment, but I wouldn't mind lowering it, wondering if I can get the same clearance with lowering springs? I was looking at Hotchkis Sport Springs.
Thanks all. |
#2 |
Drives: Crapcan
Nope.
Lowering springs are similar diameter as stock to sit on the factory perches. If you look, the clearance issue is usually right at the perch as well. It was on my car. |
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | strat61caster (03-28-2019) |
#3 |
Thanks!, follow up question then, would any coilovers work, ie are they universally smaller?
#4 | |
Drives: Crapcan
Sent from my Moto E (4) Plus using Tapatalk
| Swift Springs-On Clearance!!! | FBPARTS | Brakes, Suspension, Chassis | 8 | 12-03-2015 01:37 PM |
| Swift Springs Spec-R in Stock! CLEARANCE SALE! | Corner3garage | Brakes, Suspension, Chassis | 196 | 05-09-2015 02:46 PM |
| Cusco Zero A, and Tein Flex coilover clearance!! | RallySport Direct | Brakes, Suspension, Chassis | 8 | 12-27-2013 02:22 PM |
| Question on Sway bar and lowering coilover | awang0528 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-28-2013 01:56 PM |
| How much ground clearance after Racecomp springs? | Bleevin | CANADA | 1 | 01-08-2013 02:10 AM |
