Old 03-26-2019, 07:18 PM   #29
churchx
churchx's Avatar
Drives: 2014 GT86
Pat: i'd be more interested to see not cleanliness from outside .. but rather how insides of calipers/pistons look with pads removed after salty winters. Even if corrosion from outside occurs, it would be more of cosmetical issue. But if they start leaking or if pistons start sticking/dragging, that's what i'd be more wary off. Also may i ask to disassemble one rotor for better look, where iron & alu hub meats up?
Old 03-26-2019, 07:25 PM   #30
radroach
Drives: car
@Pat imgur.com
The Following User Says Thank You to radroach For This Useful Post:
DarkPira7e (03-26-2019)
Old 03-27-2019, 12:07 AM   #31
Pat
Pat's Avatar
Drives: 2023 BRZ
The pistons got a little sticky after one year. I spoke with Essex about it and they said it was totally normal. I use a spreader to push the pistons back in and it works just fine. No leaking is apparent.
I replaced the rotor rings a few days ago. The aluminum/iron interface is perfect.
The Following 4 Users Say Thank You to Pat For This Useful Post:
churchx (03-27-2019), kevaughan (06-15-2023), thpark93 (03-27-2019), Tor (03-27-2019)
Scion Durability Survey aegisdrgn Scion FR-S / Toyota 86 GT86 General Forum 7 05-06-2015 12:04 AM
Basic Road Salt removal tips. DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 02-15-2013 08:27 AM
Durability of cast wheels AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-06-2012 05:10 PM
FR-S A/T strength/durability? 07stealth350z Scion FR-S / Toyota 86 GT86 General Forum 1 06-18-2012 12:58 PM
