Old 03-23-2019, 01:37 PM   #1
yoLandon
Drives: 2019 Toyota 86 TRD
Removing 86 badge
Hey guys new member here. I just recently purchased a 2019 86. I’m wanting to remove the small circle 86 badges on the front quarter panels but I’m unsure if there are holes underneath or just adhesive. Can’t seem to find any post on it using the search bar. Thanks in advance.
yoLandon is offline   Reply With Quote
Old 03-23-2019, 03:08 PM   #2
Thaeyo
Thaeyo's Avatar
Heat gun, then use high tensile fishing line (flossing motion), then followed by 3M eraser wheel, should clean that sucker right off
Thaeyo is offline   Reply With Quote
The Following User Says Thank You to Thaeyo For This Useful Post:
DarkPira7e (03-23-2019)
Old 03-23-2019, 04:00 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
He's not questioning how to remove it, he's questioning if there's anything under it besides the obvious adhesive
Old 03-23-2019, 04:26 PM   #4
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
Removed mine on my same 2019. I put masking tape around the outside of the badges to protect the paint. Gently used a plastic trim remover tool to get under the badge and pried up. Badge and adhesive came off together. Used a little rubbing alcohol to clean the area and applied wax. Done.
Don
Modern warriors saddle iron horses of chrome
Dadillac is offline   Reply With Quote
Old 03-23-2019, 04:27 PM   #5
Dadillac
I see you removed your stripes already. Almost as easy as that
Don
Old 03-24-2019, 08:22 PM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I removed those ugly warts pretty soon after I got the car, no holes under them, they're just stuck on with 3M two sided tape. Slid 15lb fishing leader under there and pulled, with some tension they peeled off taking 98% of the tape with them. Gentle finger rolling took care of the rest.
Removing Toyota badge from rear white_knight Cosmetic Modification (Interior/Exterior/Lighting) 3 08-25-2013 09:24 AM
DIY remove FR-S 86 badge and installing JDM 86 badge Tylub DIY (Do-It-Yourself) Guides 13 07-07-2013 10:24 PM
Subaru badge v. Scion badge finch1750 Cosmetic Modification (Interior/Exterior/Lighting) 3 11-23-2012 12:13 AM
Need Help Scion Badge Or Toyota Badge? Dragon86 CANADA 3 08-26-2012 12:20 PM
Removing the 86 badge on the front of the car Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-10-2012 08:37 AM
