| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2018 BRZ Limited Perf Pack
Could use a little tyre advice here
I'm a light track/autocross person (a few events per year) and have run some very aggressive summers on my VWs in the past for combined street/track use. I'm familiar with temp limits and questionable wet traction.
I do drive rather aggressively (not obnoxious, but def aggressive) and am used to grabbing traction where I can. I am also comfortable with silly treadwear and don't mind buying lots of tyres if necessary. Friction lining upgrades are in the plan. New (one year in) in RWD, and after a really "interesting" cold track day last year on the stock Michelins, I'm super suspicious of rain grooves. I'm expecting either a 215/45/17 or a 225/45/17. Haven't picked out wheels yet. On my radar: Direzza DZ102, Sumitomo HTR ZIII, Firestone Indy 500 (I am old enough to be really nervous about a tire called a Firestone anything 500). Any other suggestions or feedback specific to BRZ/86? There are tons of reviews that have little to do with 86-ing, so I tend to discount them. Hence, asking the crowd here, please! Thank you.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
#2 |
JDM Vaping Stance Nation
Drives: 2013 White
I'm a novice to autocrossing but I just got the Indy 500 based on so many reviews and have to say, they're the nicest tires I've ever driven on. Makes me reconsider cheaping out on tires from now on.
They're also re-branded Bridgestone Potenza RE003. Running 225/45/17 on my 17x8/+35
Clueless
| The Following User Says Thank You to YamahaR86 For This Useful Post: | atomicalex (03-20-2019) |
#3 |
Drives: 2019 Subaru BRZ Series.Gray
I’ve owned and autocrossed on both the sumi and the indy. The indy is the better tire of the two in pretty much every category. However it’s not great on the autox course, after a few runs it gets greasy and tends to roll over quite a bit. But if you only do a few events per year it should be fine. Great street summer tire!
| The Following User Says Thank You to Jpembry For This Useful Post: | atomicalex (03-20-2019) |
#4 |
isnt the a052 the new king of "street tire?" the re71 is nutty too. well beyond the type of tire youre talking about.
Drive upgrades. Don't buy them.
| The Following User Says Thank You to fatoni For This Useful Post: | atomicalex (03-21-2019) |
#5 |
Only users lose drugs.
Drives: All the time
Of the three you listed, I've only been on the Sumi ZIII. That said, while it was a fair enough price/performance value, it got very loud towards the end of it's life and did not wear predictably; VERY sensitive to camber. I think the Conti ExtremeContact is a better alternative for similar price, plus it's a hair lighter and it's wet performance was out of this world. I've tried autocrossing on both, and while they're not 200TW tires, they did respectably well.
As mentioned, the Firestone is just a rebranded Potenza RE003, which apparently is a decent tire but has been around for a little while now. The new Potenza S007A seems like it might be a good candidate for a hot street tire that is tolerant of infrequent autocross/track days, and the pricing looks good too. 240 TW rating suggests it's pretty sticky as well. Real track/autox tires like A052, RE-71R, etc. would likely be slower until you put some heat into them, which is fine when tracking or dodging cones, but on the street where occasional fast bursts are relatively infrequent and tires will run colder, the others would already be closer to their optimum temp.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | atomicalex (03-21-2019), wparsons (03-21-2019) |
#6 | |
Drives: '23 BRZ
You might even consider "streetable" R-comps like Nitto NT01, Yok A052, and Toyo R888R. |
| The Following User Says Thank You to ZDan For This Useful Post: | atomicalex (03-21-2019) |
#7 | |
Drives: '23 BRZ
![]() Methinks the 200 treadwear rating is specifically to make it "legal" in some classes, despite not being a real "street tire"... |
#8 | |
Drives: '23 BRZ
I've streeted on NT01s as well, into the autumn months in New England, and IMO even those had decent enough cold grip for semi-spirited street driving. |
#9 |
Not saying they can't be driven on the street, but any tire in the 200TW category are going to be further from their peak grip temps than a more street oriented model like the S007A with it's 240TW rating. Given that OP only does a few events a year, he'd be better off with a tire that was closer to it's optimum operating temp and only giving up a small amount of peak grip in exchange for not needing to come up to temps as much, so he'll have potentially more grip available immediately..
| The Following User Says Thank You to venturaII For This Useful Post: | atomicalex (03-21-2019) |
#10 | |
Drives: '23 BRZ
You should not judge cold grip by treadwear rating. There's not going to be much if any meaningful correlation. Even at the same treadwear rating some tires are optimized to have more grip sooner at colder temps and some are optimized to have grip that lasts for many laps at hotter temps.
I would put money down on the RE71R vs. S007A for initial cold grip at, say, 55F temps. But I'd also put money down that any difference between the two for street driving is going to be negligible for all practical purposes. Tire Rack tested and compared these two tires, along with the S-04, on the street and on their track: https://www.tirerack.com/tires/tests...y.jsp?ttid=239 Road test suggests RE71R superiority as far as performance. Track and slalom results: S007A's wet performance is a bit disappointing, way down from the dominating RE71R and not as good as S-04 either. If anything it seems to me the RE71R probably has better grip when cooler, if wet grip is any indication. Quote:
#11 | |
I'm well aware that TWR is a somewhat arbitrary rating; certainly across brands, and even somewhat within a brand itself.
That much I agree with, in which case the cheaper and likely much longer lasting S007A would be the logical choice to make for a vehicle driven primarily on the street, at street temps, and in street conditions, while still tolerating the occasional trackday. Let's also not forget the category of tires he's using as an example of the type of performance and use case scenario he wants is decidedly different than where an RE-71R lives.
#12 |
You guys are totally getting where I am stuck. I used to run Kumho Ecsta MXs on my B5 all summer, for track and street, and below 50°F was pretty sketchy. They had to be off the car by 45°F or it wasn't going anywhere. Track performance was excellent and warm dry street performance was excellent. I could tell you exactly how much tread I had left based on rain performance.
I'm not sure I want to deal with that every day again, but I hate hate hate giving up track day performance. Greasy tyres are the worst. However, there is also the issue that I am still learning to drive this car. I can outdrive the old B5 all day, but I'm not there with this car yet, so I'm not sure I need balls-out tyres. Just very good tyres. I have another year of work before I will be really pushing this car. I'd like to grow the car with me, rather than going to a crazy setup right away. The whole 200TWR thing is all about legal for various racing series. I think LeMons is at 190 now, they were at 220 for a long time. That led to a lot of 220-rated tyres. So there should be tons of pretty sticky 200-rated tyres now that are treading the line of being legal for various series and barely lasting 5K miles. The MXs were 220, and that was a stretch - I could get a whopping 10K and 4 track days out of a set, which meant I was tossing a new set on every spring. Fortunately, they were cheap.
www.atomicalex.com
#13 | |
The BMW is a heavy pig, good lord. With 430kg less, the S007s may be what I am looking for. I found some pretty funny differences between my big lug of a wagon and my old Scirocco - I could run pretty lazy tyres on the Scirocket (840kg!), but the B5 (1410kg) required real meat under it due to the weight.
www.atomicalex.com
#14 |
Hate to say it but honeslty if it’s your daily.. there’s a hashtag going around #justgetthemichelins... and I would have to agree.. they will outperform anything else on the street, perform well on the track, and wear at least twice as well as anything in the 200 range which will help justify the cost. Also pretty much all the 200tw and below are pretty loud, which can get old if it’s your dd. Just my opinion, but you’re going to have to decide where you want to compromise.
| The Following User Says Thank You to Jpembry For This Useful Post: | atomicalex (03-21-2019) |
| Tyre Stretch, make ride higher? Bulgy tyre | Codythatsme | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-20-2016 10:56 AM |
| Advice on wheel/tyre size | solanum | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 09-04-2015 01:41 AM |
| need help with tyre sizes | ELLEENN | AUSTRALIA | 1 | 04-26-2015 07:30 PM |
| Tyre pressures | st162celica | AUSTRALIA | 6 | 08-08-2012 05:25 AM |
| Tyre you will be getting | Staticfrost | AUSTRALIA | 38 | 06-22-2012 09:02 PM |
