#20651 |
Drives: red 2014 FR-S
I have been running these in my accord for about three months and I like them. I will see how long they last. I have a different brand in my fr-s but I wouldn't hesitate to run these. I don't know how long these are on sale for.
https://www.dealnews.com/Snorda-H11-.../17924355.html |
| The Following User Says Thank You to fx1mark For This Useful Post: | Spuds (03-15-2019) |
#20652 |
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
Not today, but Saturday, I celebrated the 4th anniversary of taking delivery of my 2015 FR-S. I'm right at 30K miles per year, with 120,120 miles on the odometer when I filled up Friday night.
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
#20653 |
Drives: 2013 pearl white FR-S
took the car in for an oil change at one of the nation's largest dealership a few weeks back and car was sluggish since then.. finally popped my hood and found that they overfilled it.... by a lot
#20654 | |
(sorry, I had to ask) Well, on the bright side you got extra oil - (that is the reason I always check the oil level after a oil change, before I leave the lot) I doubt that that amount of overfill is causing the engine to run sluggish. However, if the overfill is causing the oil in the crankcase to foam, it ain't doing the engine any good. I'd drain out a quart and keep it to top off the oil if necessary. humfrz |
#20655 | |
i'm going to drain it later.. i think there's at least half quart extra... at least.. |
| The Following User Says Thank You to DarkSideFRS For This Useful Post: | humfrz (03-20-2019) |
#20656 |
Drives: Scion FR-S
Nice!
I don't drive fast, I fly low
#20657 |
Drives: 2018 86 GTS
I got to 7500km, so figured I’d change the oil. I bought a couple of 5l containers of penrite 0W20, and an oil drain pan, with a coarse plastic screen across the top.
Put the car on chassis stands, put the drain pan underneath, and opened the sump plug. Oil hit the screen on top of the pan, which succeeded in ensuring most oil was redirected upwards, landing pretty much anywhere but the pan. Thankfully the oil was very clean, so after a quick shower, a few kilos of kitty litter, and a couple of litres of degreaser the garage floor is back where I started. Next time I’ll raise the pan up closer to the sump, and remove the screen. I didnt bother swapping the filter. I’ve put 5l back in and it’s 1/3rd of the way up the dip stick, so I reckon maybe 100ml more and I’m done. |
#20658 | |
Check out the Fumoto valve. It makes oil changes super easy. You can attach a hose to the valve which goes down to your can so even on a windy day it doesn’t make a mess. Also make sure you change the filter soon. |
| The Following User Says Thank You to ermax For This Useful Post: | suzyj (03-23-2019) |
#20659 |
Drives: 2018 86 GTS
OMG what a stupendously good idea. Definitely installing one on the next oil change.
#20660 | |
Yep. No more replacing crush washers either. You also don’t have to wait for the oil to cool before draining because it isn’t going to run down your arm. You just need to be quick when you flip the lever because the valve itself will still be hot. Hahaha |
#20661 |
Took the car back to the dealership and the foreman noted that he couldn't replicate sluggish acceleration during test drive... Yeaaaaaaaah, I fully expected him to rev down the dealership parking lot
![]() And yet, they found my car was overfilled by half a quart . ![]() At least the guy gave me a voucher for a free oil change... |
#20662 |
Installed speed bleeders, Cusco differential brace, and Whiteline subframe bushings
| The Following User Says Thank You to Ashikabi For This Useful Post: | MJones_RB (03-26-2019) |
#20663 |
Drives: 2013 FR-S MT Hot Lava
Switched back to the summer wheels this weekend. Here in the Chicago area,this time of year,you can expect almost any type of weather,but Saturday was a perfect day to do it and it looks like we will be well above freezing from here until next winter.
#20664 |
Drives: 13 FRS
Yesterday.. sunday.. but better late than never
![]() New FL wheel bearing/hub New FR wheel bearing/hub new front rotors & pads brake flush with OEM fluid Summer wheels + all season tires.. took off the winters will do rear hubs + brakes in the next month or so.. bank account was hurtin |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
