Old 03-10-2019, 10:41 AM   #169
WNDSRFR
Drives: FR-S,GTI
Originally Posted by soldi3r View Post
Car ran fine before I took it in. They replaced the valve springs while I had my clutch replaced. Less than 500 miles later I was sitting on the side of the freeway with a bent rod. The paint on the new valve springs came off, clogged and choked my engine resulting in a bent rod.
Bad news: Recall broke my engine.
Good news: New short block thanks to Subaru and currently enjoying the 2019 Forester loaner while my car is in the shop.
So...
The paint flaked off the springs, clogged up the oil and blew the engine heh? This is a new one. I think it's about time that they recall the recall. It's obvious that many more cars are blowing up because of the recall than ever would have blown up on their own. In other words, you are much more likely to have your car "stall" after the recall than if you hadn't had it done. So it is a lot less "safe" to drive your car after the recall. It is after all, all about safety.
The Following 4 Users Say Thank You to WNDSRFR For This Useful Post:
CT86 (03-16-2019), humfrz (03-10-2019), RallySport (03-10-2019), Teseo (03-10-2019)
Old 03-10-2019, 11:21 AM   #170
maslin
Benz Tech
Drives: 2017 BRZ Premium
I believe there was a section in my letter indicating that you can have the repair performed by an independent mechanic and file for reimbursement (Q8 in the FAQ you linked) which should get the VIN on the list of vehicles that have been repaired.
My current thought is having The Racers Line do the work (I also need a throwout bearing replaced, the leaky timing chain cover resealed, and an overall engine health check), but I haven't called him up about it yet.
I'd rather pay out of pocket to have the engine built by someone I trust, I'd DIY but as I'm not ASE certified I have a hunch that'd be a big fat waste of time.
You may be reimburresed if the work was previously performed. You can not choose to have the work done somewhere else. Only the dealer can perform the recall.
Edit: I’m my experience that’s a big may. The exact failure better be listed on the RO, and it’s probably going to have been done at the dealer.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
strat61caster (03-10-2019)
Old 03-10-2019, 11:32 AM   #171
blitzpa9
choke
blitzpa9's Avatar
I'm scheduled to take my BRZ @ 54Kmi in this week to the Subaru dealer for the recall...
I've had zero issues with the car to this point and I really really don't want to lose the trust I have in it. This thread has me fearing the outcome and wondering if it's logical to not have it done and wait it out or just heavily monitor the job and over-communicate with the service techs.
blitzpa9 is offline   Reply With Quote
Old 03-10-2019, 12:03 PM   #172
gravitylover
If I take mine to my regular dealer I won't get to communicate with the tech at all. They never allow the customer to speak with anyone other than the service adviser. That's a big part of why I haven't had it done yet, I won't leave a perfectly well running car for a partial engine rebuild if I can't communicate with the person doing it. The other local Subaru dealer is generally not the friendliest place around but there's a guy in the shop that's pretty savvy and does some great work on Subies outside of work so I need to get in touch with him.
The Following User Says Thank You to gravitylover For This Useful Post:
NoHaveMSG (03-10-2019)
Old 03-10-2019, 12:34 PM   #173
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
And if it does fail, and they pull it apart to inspect it, you are still going to be stuck with the disassembly bill if they chose not to cover it
CT86 (03-10-2019)
Old 03-10-2019, 02:38 PM   #174
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Why would you do that when you can have the recall work done, plus all that other stuff, for the cost of a TOB, down at your local Bay area Toyota dealership, by a highly trained, highly certified, highly experienced mechanic with a PhD in FA20 engineering and maintenance - ??
ineedyourdiddly
humfrz (03-10-2019)
Old 03-12-2019, 05:19 PM   #175
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
I haven't seen the comparisons, but does anyone know if there's been a better success rate with BRZ's being repaired at Subaru dealers?
Also, can you take a recalled FR-S into a Subaru dealer for the same recall repair service?
sofrsnsokleen is offline   Reply With Quote
Old 03-12-2019, 07:01 PM   #176
Yes.
No.
Old 03-16-2019, 05:03 AM   #177
ORrooster
Drives: Your FR-S like he stole it.
Originally Posted by why? View Post
Originally Posted by PWBRZ View Post
Exactly. I just wish I had a choice; in CA you have to take it in.
great reason to leave that state.
I hear North Carolina is nice.
It is raining in Oregon.
"99% of life is what you make of it. So if your life sucks, you suck." ~ Mike Muir
ORrooster is offline   Reply With Quote
Old 03-16-2019, 05:11 AM   #178
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
NC isn't too bad, but if I had to choose I'd pick a state with no emissions laws, no income tax, and no snow. If I didn't have family here I wouldn't be here most likely.
why? is offline   Reply With Quote
Old 03-19-2019, 12:23 PM   #179
blitzpa9
choke
blitzpa9's Avatar
Just to follow up the valve spring recall work on my brz was successfully completed at the dealer. I had them replace the spark plugs at the same time. They had it for an entire week.. Mon-Mon. No noticeable issues after ~100 miles but I've not pushed it at all. Hopefully this reduces some of the uncertainty for brz owners and I will update my post if anything changes.
The Following 2 Users Say Thank You to blitzpa9 For This Useful Post:
mswbrz (03-19-2019), Teseo (03-19-2019)
Old 03-19-2019, 01:50 PM   #180
ka-t_240
Please add your failure to the registry thread if you have not.
ka-t_240 is offline   Reply With Quote
Old 03-19-2019, 01:52 PM   #181
ChrisChan
Drives: Raven 2013 FRS
Danggg. Been reading all the horror stories and I am sceptical about getting the recall done
Sounds like more people are having problems after cuz the freaking techs aren’t even following the manual at Toyota. I’m scheduled to get it done next Monday. My local dealer said they have done it 4 times, but it sounds like from some people that even then the techs screwup. Idk if MacHaik Toyota is any good sooo if any one has gotten it done from them and has not had any problems yet plz leme know
ChrisChan is offline   Reply With Quote
Old 03-20-2019, 08:20 AM   #182
why?
why?'s Avatar
Drives: series.blue
unless your car only has 3000 miles or so there is no real reason to have the recall done, and plenty to not have it done yet.
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 103 09-25-2020 03:10 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 01:10 AM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
