Drives: 86 gt
Valve spring failure
Has anyone had a valve spring fail??What were the symptoms? My car is on the list for recall and i dont like what i hear.
#2 |
There were two guys. The engine makes weird noises and may or may not run. You will get a CEL.
#3 |
Drives: 86 gt
Two cars .Are the race car guys having problems?? I my take my chances and not bother with the recall .
| The Following User Says Thank You to sandy s For This Useful Post: | DarkPira7e (05-07-2019) |
#4 |
0 issues with my BRZ covered by this recall. Car has ~5000 track miles and 100+ autox events.
I have a friend with a supercharged BRZ that was down power. The motor was taken apart, and couldn't find anything wrong with it. The machine shop started some advanced testing, and found that it had a couple of valve springs that were "weaker" than the others. |
| The Following 4 Users Say Thank You to ka-t_240 For This Useful Post: |
#5 |
Drives: 86 gt
O K lets try a different approach. Does anyone think there car runs better,more power or any difference?? after the recall
#6 |
No. It is just replacing a potentially faulty spring with one that shouldn't break. It isn't an upgrade.
| The Following User Says Thank You to Tcoat For This Useful Post: | Summerwolf (05-07-2019) |
#7 |
Drives: 86 gt
I was thinking if the springs were getting soft,weak from age and use the car may run better after new springs??
#8 |
No. They are faulty. If they break it is sudden and catastrophic.
#9 | |
humfrz |
#10 |
It's true. I'm no average driver.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | gravitylover (03-20-2019), Teseo (03-20-2019) |
#11 |
Drives: 4wd zooks
Back in the good old days , some performance cars had double valve springs , so if one failed the secondary spring just might save catastrophic failure.
#12 | |
True but the double spring configuration wasn’t for redundancy it was simply to gain stiffness for higher RPM applications. If one snapped you wouldn’t have enough spring force to prevent valve float through the entire rev band. If an inner spring broke maybe the engine would survive at lower RPMs. I’m not sure it would even idle if an outer broke though. It’s all sort of a guessing game what happens when a spring breaks though. What if it breaks and then blocks the full range of the valve? Sounds like instant failure in that scenario. |
| The Following User Says Thank You to ermax For This Useful Post: | Open Loop (03-20-2019) |
#13 |
with so many of these recall threads going I'm not quite sure exactly where to ask, but instead of creating yet another thread until I can contribute some decent information I figured this thread is as good as any..
I have searched for the last day (since I discovered that the car i bought, '13 frs is still on the list for a recall) regarding the J02 recall and what I should expect if the valve issue has already presented itself... my cylinder 3 has had a misfire I have been trying to trace and it looks like compression is way low (90psi compared to 180 on cylinder 1). I have contacted Toyota/Scion via their recall number they provide and asked a ton of questions and got scheduled with a local dealer to "inspect car before ordering parts" this saturday.. My question that I can't seem to track anywhere is... (if it really is a faulty valve/spring) if the problem already occurred with the engine (possibly causing other damage?) would they take on the recall/get the car operational again? Its also going to be fun since the car literally has no plates/is not registered due to the fact that I can't drive it anywhere because of the issue that seems like it manifested itself in my driveway while doing a coolant fill.. |
#14 | |
Senior gif poster
Drives: 2013 Asphalt FRS
To answer your question if they would take on the recall, they have to as far as I know because it is a safety concern. |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| valve spring issue? | nikitopo | Issues | Warranty | Recalls / TSB | 1037 | 05-01-2019 10:55 PM |
| Valve Spring Failure With Forced Induction? | mrhemi | Forced Induction | 2 | 03-17-2019 07:35 AM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
