Drives: frs
Update on J02 recall failure.
2013 frs 120k
*update after recall failure Long story short, my engine was knocking occasionally and i been fighting with the dealer that there is a problem but they kept saying my car is fine. ( i been at the dealer almost 10 times, demonstrated the noise to service manager, director, tech). After complaining to Corp, i got a call from the GM and told me to demonstrate the noise and tech finally admitted hearing some "ticking". But a Toyota corp. guy who travels around, happen to be in the area and he drove my car, and told the Dealer that it is knocking.(this is what GM told me) And i got another call from GM, asking for permission to wait for Toyota corp engineers to show up the next week. And today, they came and oversaw the engine tear down. And lo and behold, sealant is all over the pick up screen. Dealer finally admitted fault and giving me new short block. Toyota is not paying for anything, dealer has to eat the cost. To be honest bearings doesn't look too bad, the ones i saw. Here's some pictures. https://imgur.com/a/HGboxTZ Video of timing cover. [ame]https://www.youtube.com/watch?v=_c1bKuaisPc[/ame] Video of cams and some bearings. Last edited by msaikhan; 03-18-2019 at 06:39 PM. |
| The Following 5 Users Say Thank You to msaikhan For This Useful Post: | caus (03-18-2019), DarkPira7e (03-18-2019), humfrz (03-18-2019), PulsarBeeerz (03-19-2019), shiumai (03-18-2019) |
#2 |
Drives: 13 Subaru BRZ
Are they going to warranty the new motor?
#3 |
Drives: '13 FRS, '18 WRX, '21 M3
Um, wow. The amount of broken off excessive sealant is mind blowing .
#4 |
#5 |
Drives: frs
#6 |
I see very little if any packing at all on the top of the grove on your timing cover. Not only would most of the packing squeeze into the cover but it probably would have leaked before too long. This is the second cover I’ve seen now where they didn’t lay the bead in the right location. They all seem to think it goes inside that grove when really it belongs on top. The instructions have an illustration for toddlers showing a big red X saying not to do it like they did yours.
| The Following User Says Thank You to ermax For This Useful Post: | msaikhan (03-18-2019) |
#7 |
Rust bucket enthusiast
Nice fight. NICE FIGHT.
#8 |
2013 FR-S Whiteout / SSC
That first video should be shown to every tech that is doing this repair.
#9 | |
Drives: frs
#10 |
msaikhan
msaikhan I was just communicating with you through FB in the normally aspirated FT86 group about this. My car is at the shop right now getting this done. I am considering pulling the oil pan and oil pickup tube and checking things out after about 100 miles following the repair. If anyone has a link to good instructions for removal and replacement of the lower oil plan/oil pickup tube I would be interested. Thank you. |
#11 |
I’ve never dropped the pan with the engine in the car but another member just dropped his pan after the recall and did it without pulling the engine so I know it’s possible. You would need to remove the header and then simply remove all the oil pan bolts and then use a putty knife and hammer to work through the packing. Before starting order a tube of Threebond 1217H. You will need a caulk gun to apply the packing.
Also before cleaning make sure you clean ALL of the original packing off the pans. Try hard not to scrap the pans. Use a plastic putty knife to remove the old stuff. It’s a pain in the ass. |
| The Following User Says Thank You to ermax For This Useful Post: | Open Loop (03-18-2019) |
#12 | |
Sent from my PH-1 using Tapatalk |
| The Following User Says Thank You to ybotspawn For This Useful Post: | ermax (03-18-2019) |
#13 |
#14 |
I just worry that you will drop the pan and find packing in your pickup and then go complain to the dealer and they will claim you voided your warranty by dropping your pan.
I’m curious what a dealer would charge you to drop the pan and check the pickup. At least then they are doing the work and can’t pawn it off on you if they find packing. BTW, the other member that dropped his pan proactively did end up finding packing in his pickup. You could clear the pickup and possibly consider yourself lucky but there is no telling where else the packing might be stuck. |
| Failure After J02 Recall - Discussion Threads | mswbrz | Issues | Warranty | Recalls / TSB | 1654 | 05-30-2023 02:26 PM |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Catastrophic Engine Failure After Recall Work? | MJones_RB | Issues | Warranty | Recalls / TSB | 20 | 06-09-2019 09:54 PM |
| RACER X FRONT LOWER CONTROL ARM FAILURE WHILE DRIVING ON HIGHWAY: UPDATE WITH MORE D | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 12-19-2017 08:55 PM |
| Litchfield BRZ & GT86 Recall flash update | Litchfield | Engine, Exhaust, Transmission | 2 | 11-24-2012 07:02 AM |
