Old 03-14-2019, 11:34 AM   #15
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
Vehicle Mileage:156xxx
Vehicle Make: 13 FR-S
Miles After Recall Performed:158900
Other work completed with recall:nothing
VenomRush is offline   Reply With Quote
Old 03-14-2019, 12:07 PM   #16
subaru
Drives: STI
you put a 158 thousand miles on your car since the recall?
I ain't 2 good at math but I'll tell you whuutt these numbers just don't compute in my science brain.
subaru is offline   Reply With Quote
Old 03-14-2019, 01:00 PM   #17
ermax
ermax's Avatar
158900 - 156xxx = ~2900 ?
The Following User Says Thank You to ermax For This Useful Post:
VenomRush (03-15-2019)
Old 03-14-2019, 01:04 PM   #18
DarkSideFRS
Drives: 2013 pearl white FR-S
which socal dealership did you go to?
DarkSideFRS is offline   Reply With Quote
Old 03-14-2019, 01:16 PM   #19
158900 - 156XXX = 2YYY
DarkPira7e (03-14-2019), ermax (03-14-2019), VenomRush (03-15-2019)
Old 03-14-2019, 08:32 PM   #20
slowly put the beaker down and back away from the fume hood -
Old 03-15-2019, 11:14 AM   #21
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
DCH Toyota of Oxnard
Old 03-15-2019, 07:08 PM   #22
ScionWolf
Drives: '13 Scion FR-S
Vehicle Mileage:115xxx
Vehicle Make:*Scion FRS
Miles After Recall Performed:2000+
Other work completed with recall: None
Side note: sound tube was not fully tightened(gasp), but more importantly there is some cosmetic damage to my alternator. Still works so whatever.
ScionWolf is offline   Reply With Quote
Old 03-17-2019, 08:17 PM   #23
oaroyale
Drives: Black BRZ
I am taking my car in on Wednesday for the recall. I just got over 40,000 miles. It seems like a lot of people are doing spark plugs, drive belt, may be even clutch and TOB. I am just wondering at 40,000, should I even look at replacing any of these? Let's say I only have to pay for parts because the engine is already. What should I replace and why?
oaroyale is offline   Reply With Quote
Old 03-17-2019, 09:53 PM   #24
Open Loop
2013 FR-S Whiteout / SSC
I have 45,000 miles and I went with the spark plugs and TOB. Unless you are really hard on the clutch it should last many more years.
Open Loop is offline   Reply With Quote
The Following User Says Thank You to Open Loop For This Useful Post:
why? (03-18-2019)
Old 03-17-2019, 10:42 PM   #25
Teseo
Drives: frs
You accumulated a lot of miles. Any problems you got on the road beside the valve spring recall? Did you changed radiator fluid
Old 03-17-2019, 11:01 PM   #26
I would suggest you have them replace the spark plugs. Why? Because they are 2/3 wore out and they are a pain to replace when the engine is in the car.
Also, I would suggest you have them replace the TOB with the new, improved one. Why? Because, it will save replacing it on down the road.
why? (03-18-2019)
Old 03-18-2019, 07:22 AM   #27
oaroyale
Drives: Black BRZ
Thanks guy. I will do the spark plugs, drive belt and TOB. Quick question. How much should I expect to pay for the TOB replacement if it's being performed during the recall?
The Following User Says Thank You to oaroyale For This Useful Post:
why? (03-18-2019)
Old 03-18-2019, 11:36 AM   #28
The part itself costs from $35 - to $50. The labor should not be charged or maybe a few dollars. Make sure they replace it with the new, improved version.
oaroyale (03-18-2019)
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-18-2019 11:24 PM
Value spring recall and TOB clutch issue speedy racer Issues | Warranty | Recalls / TSB 18 12-19-2018 06:33 PM
Worldwide Power Steering Issue Safety Recall nzer Issues | Warranty | Recalls / TSB 27 08-08-2016 06:14 AM
Issue updating Registry. IloveBaldEagles Site Announcements / Questions / Issues 1 03-18-2013 07:19 PM
