#71 |
Drives: 2015 Scion FR-S
Similar Engine Failure in 2015 FR-S
I have a 2015 Scion FR-S that wasn't part of this recall. However, my car had a very similar engine failure last year. At the time I could not find any other cases of completely stock engines failing catastrophically under normal use. Now that so many others are having similar issues, I think this might add some credence to the possibility of dislodged sealants being the cause.
Here’s a short summary of what happened in 2018.
I had to take the car back to the dealer at 55.5k miles for an oil leak, but it was a quick fix. The dipstick O-ring wasn’t seated properly. I have done about 3000 miles on the new engine so far, and everything seems ok so far. Now that I’m reading about these engine failures, I plan to add as many miles as I can to make sure any problems are flushed out before the 1 year warranty on it expires. ![]() ![]()
#72 |
Drives: Scion FR-S Asphalt MT
Frustrated
Vehicle Mileage: 108000
Vehicle Make: Scion FRS Mileage After Recall Performed: 2000 Symptom(s): Knocking, shutdown on highway Failure: Engine is done. Not making a sound. State: Quebec Is Dealership Offering Repair: Unknown at this point, still diagnosing |
#73 |
Drives: Stock BRZ
So, my 2013 BRZ 77k miles, “So the Tech did your recall, after the recall, it was idling weird and acting stupid, the cam gear sprocket died and needed to be replaced, it got replaced and was running fine with no issues. Took it on the test drive I was looking at the vvt angles, and everything was looking good then he was at 5-6k rpm making sure it was good then oil pressure dropped vvt went crazy, and it rod knocked. BRZs have been having issues non stop after recalls, so you will more than likely end up with a new block.”
Given to me straight from the tech doing the data monitoring. |
#74 |
So far it seems we've gotten two articles on two different car sites made that's talking about this thread and the damage done to the cars. While I hope no one else has to deal with this stuff, I would encourage anyone that knows people that have had this happen, and haven't signed up on here to do so and put the info into this forum. Who knows if we get enough people this could possibly get notice from Toyota, and subaru.
#75 |
Drives: 13' 86
My car is a Scion FRS
I bought it Nov 12, 2012 I have 54,454 miles on the vehicle 3/11/19 W/ AEM Intake & Borla full exhaust The engine is apart and at the dealership. Toyota asked them for pictures of my Camshafts and camshaft housing. I talked to the dealership and toyota wants me to be aware of the camshafts and housing. If i want it repaired they said i will have to pay the 2k$. How does all your camshafts look? Camshafts are on backorder so i have to wait... Hmmmm Mine are so bad they can catch fingernails in the grooves. |
| The Following User Says Thank You to Malcolm87 For This Useful Post: | humfrz (03-17-2019) |
#76 | |
![]() Well, that cam does look a bit rough to me, but, maybe that's the way they are? I'll ring up ol @ermax for you for an opinion, he's had his engine apart. humfrz |
#77 | |
My fear is if your cams are that oil starved, what do your rod bearings look like. |
| The Following User Says Thank You to ermax For This Useful Post: | Summerwolf (03-17-2019) |
#78 | |
Only happy when it rains.
Drives: series.blue
| The Following User Says Thank You to why? For This Useful Post: | ermax (03-17-2019) |
#79 |
Drives: FR-S 10 series
Just got my car back from the dealer for this recall. The car feels horrible. The engine chirps continually after 2k rpm (i never had that issue), there is often a horrible knocking sound and traction control activates randomly pushing my car off to one side. Im taking the car back tomorrow, not driving it till then. Might lead to failure if I push it.
#80 |
Drives: 13' 86
There is a thread that a person started called scorned camshafts and he stated his camshafts are like mine during jo2 recall. There is no way in hell they should look this bad at 55k miles.
#81 | |
They regulate safety related recalls. They don't give one shit if the work done in those recalls causes engine failure. They have zero that they could or would do about the post "repair" failures.
#82 | |
I find it interesting that they would recall the springs that affect several models and engines but have a very low failure rate while appearing to totally ignore the oil issues from the one model.
| The Following User Says Thank You to Tcoat For This Useful Post: | mswbrz (03-18-2019) |
#83 | |
Drives: frs
#84 |
Drives: 2013 FR-S SWP
Looks like it's my turn to join the thread.
Vehicle Mileage: 162000~km Vehicle Make: 2013 Scion FRS Mileage After Recall Performed: Less the 300km Symptom(s): Engine started knocking while decelerating, then shut off. Failure: spun bearing State: Ontario, Canada Is Dealership Offering Repair: Dealship has told me they will stand behind their work and are taking responsibility. They have ordered a new crank, connecting rods, and bearings. Will take 7 days to ship for California. They are doing the rebuild of my motors which has me worried. I went in for the recall Monday March 4th. The work was complete on the 11th along my with my clutch, flywheel, throughout bearing, and spark plugs. Just 30 min ago my car died on the side of the road after a lot of clunking. I haven't even used half a tank of gas. The car was serviced at Erin mills Toyota in Mississauga. It being towed there now, I've left a voicemail with the service rep. I was contacted by my service rep this morning, and was told they will try to get the car looked at today. So far the dealership has been very co-operative. All this before leaving on vacation next Monday.
| Tags |
| fa20, failure, recall, spun bearing, subaru, toyota, valve spring |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
| TSB / Recall thread take over | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 17 | 02-18-2019 11:24 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| PA Monogram Registry! | kazetaro | NY / NJ / CT / PA | 0 | 06-06-2014 06:49 PM |
| Another Detonation thread. (DI failure related) Input Please. | Thorpedo | Issues | Warranty | Recalls / TSB | 15 | 08-02-2013 07:23 PM |
