Old 03-14-2019, 05:38 PM   #15
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Was the exhaust flow out of and over the hood ever factored into the Fluent models?
cactus is offline   Reply With Quote
The Following User Says Thank You to cactus For This Useful Post:
86MLR (04-19-2019)
Old 03-15-2019, 04:55 PM   #16
plucas
plucas's Avatar
Drives: Subaru
The exhaust flow was not modeled into the Fluent cases. There were a few reasons for this. First, this was a quick build so not a whole lot of development went into it. We only had a week for CFD development and the majority of that went into refining some of our best practices and yaw and ride height sensitivities. Given more time, that is something that we would look into. The issue is that the mass flow out of the exhaust would be steady and would be hard to estimate this flow given all situations. We would probably run it at the max flow rate, mid, and none to see how this would affect the results. I would assume this would cause the body of the care more lift. Not sure on its effects on the rear wing.
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
cactus (03-18-2019)
Old 03-18-2019, 09:06 PM   #17
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Episode 6 was posted on Friday: [ame]https://www.youtube.com/watch?v=k-jIZ2vBBpc[/ame]
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
subielife (03-19-2019)
Old 03-31-2019, 12:01 PM   #18
VerusEric
VerusEric's Avatar
[ame]https://www.youtube.com/watch?v=0Vblp92cbfs[/ame]
Episode 7: Cooling system work and cutting of the trunk to fit the uprights.
Episode 8: Received the dual element wing which is our own custom profile that works extremely well with our 300mm wing profile. We go over ducting of the cooling system in further detail and we begin bonding the front splitter.
Let us know if you have any questions .
Thanks,
Eric
Old 04-10-2019, 10:10 PM   #19
VerusEric
VerusEric's Avatar
Episode 9 is out! We show a lot of the front splitter being built and begin working on the flat underbody panels.
Picture of the flat underbody.
We are getting close to finishing all the small odds and ends. Probably 3-4 more videos before the car is finished.
Eric
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
Kiske (03-01-2020), new2subaru (04-13-2019), Victorscp (04-13-2019), wparsons (04-12-2019)
Old 04-13-2019, 07:18 PM   #20
Victorscp
Drives: 2018 BRZ premium
Flat
FLAT BOTTOM CARS YOU MAKE THE RACING WORLD GO ROUND!!!
Victorscp is offline   Reply With Quote
The Following 6 Users Say Thank You to Victorscp For This Useful Post:
Captain Snooze (06-03-2019), KDad2 (02-29-2020), new2subaru (05-27-2019), Pat (04-13-2019), TMF (04-19-2019), VerusEric (04-14-2019)
Old 04-13-2019, 10:31 PM   #21
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Episode 3 is out! We talk a bit about the cooling system, the CFD CAD model, and CFD.
How do you guys deal with the engine bay interior? Is it assumed solid or is there a way to simulate flow through the radiator and out the vents? Or is it accurate in the solid model and CFD?
Old 04-14-2019, 09:50 AM   #22
plucas
plucas's Avatar
Drives: Subaru
Engine bay we do not simulate. We will simulate heat exchanger stacks at times when it would affect items we are looking into. We did not simulate the stacks in this case as it would have been difficult. We do not have pressure drop data for the intercooler. We have the pressure drop data from the rad and could get it with the OC. If it had ducting out the hood and not into the engine bay, we might have simulated it (if we had data for the intercooler).
Spuds (04-14-2019)
Old 04-14-2019, 10:40 AM   #23
Spuds
The Dictater
Spuds's Avatar
Thanks, that makes sense with the schedule you have, but I wasn't sure if you had any fancy tricks to make that work. From your prior experience, how much difference does that make in the predicted front splitter performance? Do you account for that in the design?
Old 04-19-2019, 07:51 AM   #24
plucas
plucas's Avatar
Drives: Subaru
Not much on the splitter. It does affect overall drag though. Trends are still valid for A to B tests. Drag will be higher when you have any sort of heat exchanger added to the mix.
Spuds (04-19-2019)
Old 04-19-2019, 07:33 PM   #25
VerusEric
VerusEric's Avatar
Episode 11 came out. We wrapped up the build . We'll be doing a few more videos concluding the overall build as well.
[ame]https://www.youtube.com/watch?v=fQDgBcwhhoE&t=2s[/ame]
Photo of the rear by Dustin Kessler
Thanks,
Eric
Kiske (03-01-2020)
Old 04-30-2019, 12:12 PM   #26
VerusEric
VerusEric's Avatar
We are working through our recap videos on the car now. First up is the cooling system recap!
[ame]https://www.youtube.com/watch?v=T52HDYx9XvQ[/ame]
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
Lonewolf (05-05-2019), Shadotracker (05-06-2019)
Old 05-20-2019, 08:32 AM   #27
VerusEric
VerusEric's Avatar
Front Splitter Recap Video:
[ame]https://www.youtube.com/watch?v=Ja0lsoG3aZ8[/ame]
Before it is asked, the bumper to the splitter will be sealed. Currently, our thoughts are to use heli-tape/racer's tape. Later on, FT86SF may do something here to improve upon the tape but tape will work for right now.
FT86SpeedFactory did a recap as well with the car:
Thanks,
Eric
Old 05-27-2019, 08:53 PM   #28
VerusEric
VerusEric's Avatar
Another recap video for those interested . The car will be going to GTA Mid-West event this weekend for some shaking down.
[ame]https://www.youtube.com/watch?v=0y2e_YkFB2I[/ame]
MachMotorsport 2018 BRZ tS GT3 Time Attack Build Scracho Member's Car Journals 6 02-08-2019 01:52 AM
LS3 HPDE / Time Attack Build RavioliG Member's Car Journals 17 02-11-2018 03:56 PM
King Tut's Time Attack Build King Tut Member's Car Journals 225 05-15-2017 01:44 AM
Robispec TIME ATTACK Build robispec Tracking / Autocross / HPDE / Drifting 254 11-18-2014 04:27 AM
The time attack build by Rob SavingManuals Member's Car Journals 8 04-27-2014 08:01 PM
