#225 |
Only users lose drugs.
Drives: All the time
Correct...more to the point of the fire itself precipitating from the recent underhood work, not specifically mechanical engine failure due to the recall itself being performed sloppily...but still, sloppy work.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | Dadhawk (03-13-2019) |
#226 | |
#227 | ||
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#228 |
You're still forgetting the fact that this was the first time his driving conditions were notably different than the past 2 weeks of travel. The fact that they changed to even more extreme conditions points could easily cause an otherwise just-barely benign leak to turn into a genuine fire source. Vehicles have leaks all the time that go unnoticed until some new event causes their presence to be discovered. Sometimes discovered with extreme prejudice. Lol.
#229 |
Not that it'll ever be done, but I bet that motor was torn down, it'd be completely fine internally (aside from massive overheating...). None of the description the poster provided sounds like internal mechanical failure. A 2000psi fuel line rupturing from a surrounding fire, on the other hand, could certainly produce those symptoms.
#230 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (03-13-2019) |
#231 |
Good point, and makes sense.
#232 | |
Famous Potatoes
Drives: '15 ultramarine
Now that would be interesting. My first thought were along the same lines; something with fuel. Either way, engine failure, or sloppy re-assembly of fuel components = recall related. Be very interested how this ends up. I bet if he had not had the recall done, his car would be in his garage now. We may never know. |
#233 | |
Actually, my money would be on a slow-ish oil leak that eventually caught fire, and then the rest of the underhood domino effect as the fire spread.. An oil leak could hide for weeks or even months before the right conditions caused a fire.
| The Following User Says Thank You to venturaII For This Useful Post: | Sapphireho (03-13-2019) |
#234 | |
Speaking of failures we have a new report of a new spring breaking and dropping a valve. This sounds suspect to me. Probably didn't get a good set on the keepers and it popped. |
| The Following User Says Thank You to ermax For This Useful Post: | Dadhawk (03-13-2019) |
#235 |
The one thing I find odd about the fire case is they didn't say if there was a hole in the block and it's been long enough since the incident that I would have expected that to be known. I would hate for this engine to be tossed aside and not used as another example to help out others getting denied repair after failures. Seems a fire would get Toyota motivated but if they never know it happened then it's a lost opportunity.
#236 | |
#237 | |
I say we just wait for the owner to give more details. Hopefully he isn't a one hit wonder never to be seen again. I'm very interested in his case because I think it will put the most fire under Toyota's ass. |
#238 |
Drives: FRS
my cars going in tomorrow
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
