Old 03-13-2019, 11:44 AM   #1
xjohnx
Grip>Slip
xjohnx's Avatar
Question Potential protest impacts of avoiding valve spring recall?
Since Subaru has identified the valve springs as being out of spec/manufacturers tolerances on a certain subset of 86s, I thought of an interesting hypothetical.
If someone opted not to have that recall performed for whatever reason and was running stock class at a SCCA national event, what are the chances of a mechanical protest succeeding on a technicality?
Old 03-13-2019, 11:47 AM   #2
ka-t_240
If someone opted not to have that recall performed for whatever reason and was running at a national event, what are the chances of a mechanical protest succeeding on a technicality?
Zero. There is no way to prove the recall was done. There is also no "advantage" to having the old springs. They are just more prone to being weak/breaking. Not like the cars with recall done would be down HP.
That would be like saying, my friend with a 13 BRZ that is in the recall population but alread blew one up, could be challanged because he has a motor out of a non recall car.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
strat61caster (03-13-2019)
Old 03-13-2019, 11:57 AM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
Do the rules require someone being able to prove there is an advantage gained by using non-spec parts? I thought it simply had to prove the presence of non-spec parts. As far as proof goes, I am under the impression that when someone files a mechanical protest, a teardown would be performed at impound once the appropriate protest fees are paid.
The update/backdate rule covers your second scenario.
Old 03-13-2019, 12:06 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
Found this in the SCCA rulebook, for what it is worth.
Old 03-13-2019, 12:35 PM   #5
ermax
ermax's Avatar
They actually changed the spec mid 2014 (or somewhere around there) so any cars built after that would have the same springs you get on the recall anyways. There is no performance difference between the springs.
Old 03-13-2019, 01:20 PM   #6
ka-t_240
For SCCA Up/Back doesn't classify for "street" class does it?
Also - There is no way they would be pulling an engine at a SOLO event for protest. Once apart, I doubt they would even be able to know what spring is what. I haven't had FA apart, but I don't think the springs have part # on them. If they really wanted to know, you could check recall status on a SN # vs pulling an engine.
Old 03-13-2019, 01:34 PM   #7
ermax
ermax's Avatar
The new springs are painted on the end though.
Old 03-13-2019, 01:54 PM   #8
1. How would anyone know you did or didn't have the work done?
2. @xjohnx are you saying that if you participate in a sanctioned event with your street car you have to allow a teardown of the car in the case of protest? I don't do these events but that seems like a pretty huge deterrent for a non-dedicated race vehicle. It's not like it's Formula 1 or NASCAR.
Old 03-13-2019, 01:57 PM   #9
steverife
Drives: 2016 Scion FRS
You aren't required to replace every superseded part.
steverife is offline   Reply With Quote
Old 03-13-2019, 02:01 PM   #10
steverife
For a national event, there is a protest process. If the protestor wants to tear down someone's engine, a pretty significant bond is required (think shop time rates for disassemble/reassemble). If they are wrong, they lose that money. The protested party could simply refuse, but of course, you lose the protest.
Old 03-13-2019, 02:03 PM   #11
OK, makes sense, as long as you have the option to refuse. I mean, folks are concerned about qualified Toyota/Subaru techs doing this tear down, what must they think in that type of situation!
Old 03-13-2019, 07:51 PM   #12
PointDSM
PointDSM's Avatar
Drives: 2013 Subaru BRZ
I can't wait to see the top 10 for Nationals in SCC all be 2013's, that will put the Sawyer National Course controversy to shame.
PointDSM is offline   Reply With Quote
Old 03-13-2019, 08:18 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
I mean, going by the letter of the law of the recall provision posted above, they'd have a pretty good argument (I guess it depends on whether anything out of OEM spec fails or if it actually has to give a performance advantage, but in that case, who would be the judge?)
You KNOW autocrossers love technicalities.
Mr.Scion (03-14-2019)
Old 03-13-2019, 09:26 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
If it's a mandatory recall, the grounds exist for such a protest. If it's not mandatory, then no grounds. As noted, it's in the rulebook.
I simply don't know if the recall is mandatory 'cause I haven't paid enough attention
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
Has Anyone Brought Their Car In For Valve Spring Recall Little Mt. Fuji NY / NJ / CT / PA 33 03-21-2019 09:49 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
