Old 02-07-2019, 02:01 AM   #589
wally
SosMula
wally's Avatar
Drives: 2013 DD White pearl
Originally Posted by tomm.brz View Post
they literally linked them few posts ago
Yeah I noticed that after posting went straight to posting after reading like 20 pages. My bad =)
Rota Grid 18x9,5 ET+38 Valenti CBW GCS Shark Antenna Acrylic Headlight Covers
wally is offline   Reply With Quote
Old 02-07-2019, 04:04 PM   #590
steve99
Drives: FT86
@jmiller86
You sent me a private message but im unable to reply as you jave blocked private messages
Old 02-09-2019, 04:06 AM   #591
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by mkodama View Post
Confirmed this feature no longer works since adding the tune.
Edit: Kinda wondering if the AC shutoff on full throttle is also disabled now...
AC shut off at WOT works like normal.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
mkodama (02-11-2019)
Old 02-10-2019, 03:34 AM   #592
Boomerang
86
Boomerang's Avatar
went for a drive today to do some logging of the V4 tune in my car after a few hundred k's
was pleasantly surprised to see IAM make its way to 1 and stay there even under WOT with AC on and today was 35 degrees C
top work OFT team
Old 02-11-2019, 02:31 AM   #593
mkodama
86 Challenge
Drives: 2017 BRZ
they are not commanded by the tune in the ECM, you are thinking wrong..
I'm not sure I follow. If the variable alternator voltage isn't controlled by the ECM, then what does control it and why does the OFT tune disable it when flashed?
mkodama is offline   Reply With Quote
Old 02-11-2019, 04:39 AM   #594
steve99
Drives: FT86
Yes the alteenator is controlled by engine ECU, but i believe what @tomm.brz is sating is the tables which controll the alternator are not defined ie unknown and so have not been chamged by the openflash guys in tune.
Im not sure of the exact logic but it appears that the alternatpr may cut off durring full throttle if battery is fully charged or current draw from battery is low ie headlights not on. Also air conditioning is also controoled by ecu under full throttle in some circumstances.
Whwn tuned the logic may have changed slightly if your not a 2017 euro car as all oft tunes are actually based on euro roms not usa roms even though they may be labeled same calid. Its possible the euro roms control the alternator differently but i do not know for sure
The Following 2 Users Say Thank You to steve99 For This Useful Post:
mkodama (02-13-2019), tomm.brz (02-11-2019)
Old 02-13-2019, 11:42 PM   #595
freddydo
Drives: 1234
Originally Posted by elBarto View Post
I have the V2 on my Gdrive:
OTS V2.067
Thanks for sharing the link.
A quick question,
I'm currently running v4.03 for my 2017 BRZ MT, but the car jerks a lot at lower rpm so I tuned it back to stock today.
Would it be possible to run v2 tune for MY17/is there a tune for MY17?
I downloaded and looked into each tunes, but nothing seem to match my CAL.
freddydo is offline   Reply With Quote
Old 02-14-2019, 01:55 AM   #596
tomm.brz
Drives: brz 2017 hksv2
you could always open in romraider the v4 for your car, and open also a v2 and copypaste the tables that are different from the v2 to v4
Old 02-22-2019, 06:45 PM   #597
trxn
trxn's Avatar
Drives: 2017 Toyota 860
Is it possible to get the loud cold start back on the v4 tunes? Specifically the stage 2 plus tune.
trxn is offline   Reply With Quote
Old 02-23-2019, 12:57 AM   #598
tomm.brz
you should find it multiple times..
anyway
raise the first 2 rows of maf enrichment after starting (2 identical tables)
set ignition timing after start to -15 (the more negative the louder, euro cars now have -19 as default)
raise a bit idle speed if you want
trxn (02-23-2019)
Old 03-12-2019, 08:47 PM   #599
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
where is OTS download page now? i cannot find anything at open flash tablet page.
i still have version 1 tablet
Old 03-12-2019, 10:44 PM   #600
steve99
Drives: FT86
V1 or v2 tablet same tunrs just temlkate file is different
https://support.openflashtablet.com/...ns/42000005938
Old 03-15-2019, 09:53 PM   #601
Contender
A quick question,
What do you mean by jerks a lot at low rpm? Does the throttle respond faster ? Is it touchy with the tune?
Contender is offline   Reply With Quote
Old 03-24-2019, 06:56 PM   #602
LancePower
Drives: 2020 BRZ tS
I have 2016 and had been running v4.01 Stage 1 for about 9 months.
Just switched back to v2.076 and think I prefer it. Feels like it pulls harder in the upper Rev-range and most importantly I'm no longer hearing the "engine chatter" crossing 4K RPMs that I was with v4.01.
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
mgarcia707 (03-25-2019)
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
