69gtojeff, CT86, gravitylover
Old 03-11-2019, 09:47 AM   #43
Bigdmiata
Originally Posted by ka-t_240 View Post
Have you notified them yet? They likely will pay $0 toward an independent shop doing any work on the car.
I have reached out to the Toyota dealership that did the recall work. My mechanic is going to send the block over to the dealership for review later this week. We'll see where it all goes from there.
Bigdmiata is offline   Reply With Quote
Old 03-11-2019, 07:35 PM   #44
jesslax32
Drives: 2013 FRS Argento
Vehicle Mileage: 48,785
Vehicle Make: Scion
Mileage After Recall Performed: 10
Symptom(s): None
Failure: Dealer Error, Mechanic borked the oil regulator
State:NY (service in CT)
Is Dealership Offering Repair: YES
Car is Trouble free as of right now.
'07 Mini Cooper S Dark Silver - traded for a Forester
'15 Mini Cooper Volcanic Orange - traded for the '17
'17 Mini Cooper Electric Blue
'13 FR-S Argento
jesslax32 is offline   Reply With Quote
Old 03-12-2019, 08:11 AM   #45
DirectorBrandx
DirectorBrandx's Avatar
Drives: 13FRS
At my dealership, four FRSes have now shown up. All are awaiting a Toyota Corporate review.
In my case, here are my FRS details...
Vehicle Mileage: ~70000
Vehicle Make: Scion
Mileage After Recall Performed: ~68500
Symptom(s): Ticking started while driving on the highway and quickly became a knocking. Had it towed to the dealership.
Failure: TBD
State:VA
Is Dealership Offering Repair: Left with dealer same day 3/04/19; will update.
DirectorBrandx is offline   Reply With Quote
Old 03-12-2019, 08:15 AM   #46
DirectorBrandx
Drives: 13FRS
Updates??
My car is at our dealership for a week, now. A corporate review is underway and the corporate staff are to be arriving this week to determine what to do about the four FRS failures sitting in their service dept.
Old 03-12-2019, 08:44 AM   #47
msaikhan
Drives: frs
Originally Posted by DirectorBrandx View Post
Updates??
I wish corporate came down to my dealer to check my car out. Since my car hasn't blown engine yet, the dealer just keep blaming the knocking noise on some other sh**. The tech tried to tell me it's the high pressure fuel pump *cricket noise* when it's obviously knocking. But i left it at the dealer one more time, spoke with the GM, he said he will have them diagnose it properly, but i have 10% hope since i've been at this dealer like 10 times already. I'm also in VA but in leesburg.
msaikhan is offline   Reply With Quote
Old 03-12-2019, 10:06 AM   #48
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Having some issues with mine. Stalling while moving, feels like it's missing power down low. Fueling feels off almost. Dealership says there's no way this is caused by the recall work. I call bullshit.
Edit: they're claiming it's the injectors/tune.
When I have more info, I'll adjust my post to the correct format
wrxgoose is offline   Reply With Quote
Old 03-12-2019, 10:32 AM   #49
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Please be sure when leaving an entry here, that you're using the posted template to be sure all entries are captures in consistent format.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
fang_gt86 (03-12-2019), Leonardo (03-12-2019), NoHaveMSG (03-12-2019)
Old 03-12-2019, 12:41 PM   #50
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
@DarkPira7e Maybe I'm the only one, but I wasn't quite sure how to deal with the "Vehicle mileage" and "Mileage after recall performed" fields. I interpreted that as current mileage on the odometer and miles driven after the recall, respectively. For me, it was something like 71,xxx and 620. Is that what you were looking for? If not, let me know and I'll adjust my record.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
DarkPira7e (03-12-2019)
Old 03-12-2019, 01:40 PM   #51
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
Vehicle Mileage: 59xxx
Vehicle Make: Scion
Mileage After Recall Performed: 60xxx (671)
Symptom(s): Oil leaks at bottom of timing chain cover (may be the o ring of the dipstick). Burning smell.
Failure:
State: CA
Is Dealership Offering Repair: They are investigating.
It's not a failure yet but I would like to report it to provide some data point. It's very likely the dealer reuse the o rings that should be replaced during the recall.
I won't go to this same dealer for future maintenance or repairs anymore. When they perform J02 recall, they even forgot to roll down the window before disconnecting the battery. It may cause some damage to the weather seals. The car now has rattles around the door.
zeroomega is offline   Reply With Quote
Old 03-12-2019, 02:19 PM   #52
DarkPira7e
DarkPira7e's Avatar
How you've interpreted it is perfect.
MuseChaser (03-12-2019)
Old 03-12-2019, 06:29 PM   #53
Kdaddy
Kdaddy's Avatar
Drives: 2013 Scion FR-S and 2016 BRZ
Vehicle Mileage:74xxx
Vehicle Make: Scion FRS (2013)
Mileage After Recall Performed: +/- 350
Symptom(s): clanking noise in motor tied to rpm
Failure: spun #2 crank bearing others scored
State:TN
Is Dealership Offering Repair: Yes
I had a certified 100k warranty so they are repairing it. First want to put a used motor in it... Later decided to use a new factory short block. Dealer said there were 59 blocks on backorder with 35 of them scheduled to be delivered soon. Mine should be in next week... Went ahead and bought a used 2016 BRZ.
Kdaddy is offline   Reply With Quote
The Following User Says Thank You to Kdaddy For This Useful Post:
chaoskaze (03-13-2019)
Old 03-12-2019, 07:19 PM   #54
BRZnut
Drives: BRZ DGM Limited
Updates??
Four failures sitting at the same dealership at one time? If that doesn't say this recall is a F-up, not sure what does.
The Following 3 Users Say Thank You to BRZnut For This Useful Post:
CT86 (03-14-2019), squall leonhart (03-12-2019), Teseo (03-13-2019)
Old 03-12-2019, 07:57 PM   #55
rande
rande's Avatar
Drives: Spyder, MR2, FRS, Tundra
... and that dealership.
rande is offline   Reply With Quote
The Following User Says Thank You to rande For This Useful Post:
mswbrz (03-13-2019)
Old 03-13-2019, 11:57 AM   #56
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
If anybody cares, I put this into Google Sheets... a little easier to see all of the failures and what not, so feel free to update/add any new failures.
https://tinyurl.com/y2hy5kx4
Mike
tanner is offline   Reply With Quote
The Following 4 Users Say Thank You to tanner For This Useful Post:
BigTuna (03-13-2019), PabloN (03-13-2019), Tcoat (03-13-2019), Yoshoobaroo (03-13-2019)
fa20, failure, recall, spun bearing, subaru, toyota, valve spring
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-18-2019 11:24 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
PA Monogram Registry! kazetaro NY / NJ / CT / PA 0 06-06-2014 06:49 PM
Another Detonation thread. (DI failure related) Input Please. Thorpedo Issues | Warranty | Recalls / TSB 15 08-02-2013 07:23 PM
