Old 03-10-2019, 12:30 AM   #1
gt86yasss
Drives: White 86
Choke with Edlebrock SC on E85
I had my car remote tuned and it gets a choke occasionally around 3k rpm when accelerating after shifting gear. For instance, shift gear, engine speed drops to 2500 rpm, accelerate smoothly until 3000~3500 rpm, choke, back to normal. I tried to switch to 91 map, still happened. Just wonder if it happened to you guys as well and seeking for a solution.
Specs:
2017 BRZ manual on pure E85
Edlebrock SC
Delicious Tuning Dbox
Openflash Catless header
Greddy Supreme SP catback
No fuel mod
https://drive.google.com/file/d/1jdF...ew?usp=sharing
https://drive.google.com/file/d/1Xqd...ew?usp=sharing
https://drive.google.com/file/d/1D3i...ew?usp=sharing
gt86yasss is offline   Reply With Quote
Old 03-10-2019, 07:03 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Looks a bit fuelling related to me - goes too lean to make power. MAF appears to spike as well in that region, not sure why though.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-10-2019, 07:25 AM   #3
tomm.brz
Drives: brz 2017 hksv2
you really need to change PI injectors if you keep using e85 with that boost
DI opening time is too high over 7ms and you are getting spark just 0.5ms after end of injection. That's very dangerous
i would upgrade fuel pump also just for safety
the spike doesn't seem to happen to MAF voltage, so it must be maf scaling related, like as the tuner bumped up the scaling in that voltage zone
Old 03-10-2019, 06:12 PM   #4
gt86yasss
Drives: White 86
Thank you so much for your responses. I'm not a car guy but let me give you guys some more background. The dyno was done approximately 2 weeks after the car was tuned, and during the dyno session the shop owner told me the car was running lean in high rpm, but base on the reading he believed the injectors still have room to play with. I spoke with the tuner and he suspected the AFR reading on the dyno machine was not calibrated right and he also suggested me to get the dbox to smooth out the power curve.
I was suspecting it was fuel related too but my confusion is why it only happened in the 3-4k rpm range. If it was a fuel supply problem shouldn't it be more observable in high rpm? I'm going to do some more logging today and post it.
Old 03-10-2019, 06:32 PM   #5
tomm.brz
well, 0.5 ms end of DI to spark is totally dangerous, if your tuner is ok with that, i don't know what else to say
Old 03-10-2019, 07:03 PM   #6
Grady
Grady's Avatar
Get larger injectors and better fuel pump. You can do boost or E85 on stock injectors. Not both.
Old 03-11-2019, 04:57 PM   #7
CSG Mike
CSG Mike's Avatar
I would talk to your tuner.
wparsons (03-11-2019)
Old 03-13-2019, 03:18 AM   #8
gt86yasss
Drives: White 86
My tuner is quite responsive and ask me to provide log when it happens, but I wasn't able to duplicate the problem in the past few days. However, I did a 4th gear pull tonight and below is the log, if possible can you guys please enlight me on to read those data and what shows the sign of problem? Much appreciated!
https://drive.google.com/file/d/1lO5...ew?usp=sharing
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 02:54 AM
