Old 03-07-2019, 08:25 AM   #1
Boris_Petrov
Drives: 2013 GT 86
Built FI engine on 100 RON
To start this off I live in Europe and I don't have access to e85. With the GTX2867R I'm going to order I'll be looking to make around 380 horses. Some people tell me - stick with 12.5 compression ratio and run 100 RON, others - go for 10 or 10.5 comp and run whatever gas you want. I'll replace the con rods for sure, but my question is if I can run this much power on this gas with stock comp or should I lower the compression and go for more boost. Also I had read that e85 has a 100-110 octane rating and 100 RON obvioisly has 100 oct. so it shouldn't make that big of a difference. Maybe. If it does feel free to tell me!
Sent from my SM-A520F using Tapatalk
Boris_Petrov is offline   Reply With Quote
Old 03-07-2019, 09:24 AM   #2
86TOYO2k17
Drives: 2017 toyota 86
100 ron is 95.75 octane
E85 is 108 octane
but 95.75 is still pretty high octane. No issues with using that. Wont be able to run as much timing and boost though. Not sure you'll hit your power goal without something higher.
Old 03-07-2019, 09:27 AM   #3
Boris_Petrov
Drives: 2013 GT 86
E85 is 108 octane
So do you think I should go for 10.5 comp ratio?
Thanks for the reply by the way!
The Following User Says Thank You to Boris_Petrov For This Useful Post:
Joveen (03-07-2019)
Old 03-07-2019, 09:58 AM   #4
tomm.brz
Drives: brz 2017 hksv2
i would keep stock CR and boost around 0.9-1 bar.. if you want more hp with 100ron maybe should think of bigger turbo
would be huge difference with e85 but i'm like you, only 100ron in italy
Old 03-07-2019, 10:02 AM   #5
Boris_Petrov
Drives: 2013 GT 86
I don't know if it'll be safe tho. Sounds like a lot of boost on a lot of comp. And there aren't any tuners with expirience on this platform so I am not sure. In my country there are like 4-5 86s and 2 BRZs for sale.
Old 03-07-2019, 10:10 AM   #6
tomm.brz
if you remote tune with good master tuner and put a wideband I would not worry
if you lower CR you lose hp and then you put higher boost to compensate.. with that particularly turbo i would just keep stock CR, you said you build the motor anyway, with built engine i would personally go to 1Bar .. you re gonna be knock limited anyway by the fuel... don t know what hp you re gonna get, bigger turbo maybe would help and the high CR helps with the lag
Old 03-07-2019, 10:16 AM   #7
Boris_Petrov
Drives: 2013 GT 86
By remote tuning you mean a tuner from let's say america tunes my car via team viewer or what?
Old 03-07-2019, 10:16 AM   #8
86TOYO2k17
I am not the engine building guru. I am sure some more people will chyme in with more information in a bit.
but,
Lowering the CR will allow more boost and timing compared to higher CR resulting in more on Boost power. However off boost like in normal daily driving the lower CR will have a lot less power, less fuel efficiency, and feel "laggy".
Also you need to look at your blower and at what flow rate or boost pressure it is the most efficient at. and pair your blower size and CR to your power level goals for maximum efficiency.
Also some other options if E85 isn't available is octane boosters like Boostane (half a can should get you to 100 octane per tank of gas) or a water meth kit (a little pricey to setup at first but then pretty cheap after the initial investment).
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
Boris_Petrov (03-07-2019), tomm.brz (03-07-2019)
Old 03-07-2019, 10:25 AM   #9
tomm.brz
whatever tuner with experience in this.. there are many also in Europe
you buy an ecutek programming kit, load tune you get from them and log your driving and they correct the tune basing on that
Old 03-10-2019, 04:55 AM   #10
Boris_Petrov
Drives: 2013 GT 86
but,
I think the gtx 2867r is most efficient at around 12-18 psi
Built engine - GEN-2 GTX3076r Kris86 Forced Induction 242 05-05-2024 09:15 AM
Built engine. How hard is it? 86 South Africa Engine, Exhaust, Transmission 31 11-23-2017 06:25 PM
Built engine cost? wise345 Engine, Exhaust, Transmission 58 12-22-2016 03:16 PM
Built engine question 86 driver Engine, Exhaust, Transmission 13 09-10-2015 11:16 PM
Anyone has Stroked and Built FA Engine yet ? Whitigir Engine, Exhaust, Transmission 11 03-14-2014 05:31 PM
