#99 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Damn, some nightmare stories in here. Jun 2012 build here. Glad I'm going for a full rebuild instead of sending it back for a 'recall'.
$8.5k for a new shortblock? You can get an Outfront with that kinda money. Did you ask them if it came with a BJ
[CENTER]
Build thread |
#100 |
#101 | |
Feeling like thinking....
Yeah, I can see why folks see that in the first pic I posted yesterday... it's just a bad shot. To be honest, I didn't even realize those were holes.. I thought they were marks! In any case, though, they were both full and then some. Look at the pics I edited into my previous post a few minuts ago.
Drive like everyone's life around you depends on it...
#102 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Yeah, that's too much.
Some vinyl tubing and a dollar store turkey baster down the dip tube will get you to a less congested level. Or a FuMoto drain valve.
"I gotta rock." -- Charley Brown |
#103 |
#104 | |
#105 |
Geo Tyrebighter Esq
Much simpler to drop out a measured quart or so without losing the whole fill.
Or you can undo the sump plug and get oil all over your nitrile gloves and the floor. ... and your elbow, and, and ... ... and this should probably be in another thread altogether.
| The Following User Says Thank You to bcj For This Useful Post: | humfrz (03-06-2019) |
#106 |
Drives: Ultramarine
Just got mine back yesterday. I’m noticing a very faint smell of burning oil. Can that just be related from getting a new short block?
#107 | |
When your eyes get a bit older, I suggest you have someone else check the oil in your car - your track record is indicating that - ![]() I know that when I read the oil level on my dipstick, with my macular degeneration and poor low light eyesight and wearing trifocals, I can "read" almost anything I want to see. ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | ermax (03-06-2019) |
#108 | |
It's most likely just some stray oil burning off, not to worry. Just don't read anymore posts about the after action reports from some folks that have had the recall work done - ![]() humfrz |
#109 |
Nevermind I misread your post. You were talking about draining oil not checking the dipstick. Hahaha
#110 | |
Drives: Ultramarine
Spun rod bearing resulted in a new short block. Here I am a day later. Let’s see how long this holds up
| The Following User Says Thank You to Pinoy_FRS For This Useful Post: | humfrz (03-06-2019) |
#111 |
Drives: BRZ DGM Limited
#112 | |
Drives: 2013 Scion FR-S, Hot Lava
I had the same thing when I got mine after the recall work. I also thought it was some remaining oil. 385km later, it started knocking and my engine died. Just to be sure, keep checking, keep "being paranoid" about it for a while, and if you doubt, bring it back asap.
| Valve spring recall - where did you get it done? satisfied with the work? | fiveoneoh | Northern California | 103 | 09-25-2020 03:10 PM |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 10:32 PM |
| valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 01:10 AM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-09-2019 12:38 AM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 08:41 PM |
