Old 03-05-2019, 03:46 PM   #99
Ichima
Drives: 13' Lightning Red Brz
Noob question, but after i had my recall done. Car is rough on cold start ups, and i have a knocking noise when warm after highway speeds but goes away when i start driving again. My friend says it sounds like a timing chain issue. Are the timing chains removed when doing this job? Also had my headgaskets replaced while i was getting the valve springs done. Is it a possibility my timing may be off? I’m also throwing a code p0016
Ichima is offline   Reply With Quote
Old 03-05-2019, 04:21 PM   #100
ka-t_240
Yes, the chains are removed for this recall.
They would for sure be removed for headgasket R&R.
Sounds like you need to bring it back to the dealer and let them look it over.
ka-t_240 is offline   Reply With Quote
Old 03-05-2019, 05:19 PM   #101
Ichima
Thanks!
Is this something I should tell them when I bring the car back in Thursday? or should I let them pull the motor again and wait for what they say?
Old 03-05-2019, 06:12 PM   #102
maslin
Benz Tech
Drives: 2017 BRZ Premium
Thanks!
Is what something you should tell them? "You just worked on my car and now it's knocking and has a check engine light"? Yes, I would tell them that. They know what work was done.
I wouldn't start off with "someone on the internet said it's the timing chain".
maslin is offline   Reply With Quote
The Following 6 Users Say Thank You to maslin For This Useful Post:
ermax (03-05-2019), humfrz (03-05-2019), ka-t_240 (03-06-2019), RToyo86 (03-05-2019), Teseo (03-06-2019), Ultramaroon (03-05-2019)
Old 03-05-2019, 07:02 PM   #103
Yes, just relate the symptoms and ask them to "fix" it.
ermax (03-05-2019), Ultramaroon (03-05-2019)
Old 03-05-2019, 08:37 PM   #104
ermax
ermax's Avatar
Why did they replace your head gaskets? That isn’t part of the recall and adds a significant amount of labor. Did you pay them to do this?
P0016 could be one of a million things. Bad OCV, contamination in the gears, bad cam angle sensor or bad ECU. There have been a bunch of people having damaged OCVs after the recall. It’s probably that.
Old 03-06-2019, 08:31 AM   #105
Ichima
Dealership recommended it be done while the motor was apart. I ended up paying just for parts to have it done.
Old 03-06-2019, 09:21 AM   #106
ermax
ermax's Avatar
There is literally no reason to replace the head gaskets unless they are leaking. They totally pulled one over on you. Replacing the head gaskets means pulling the heads which significantly complicates the job because it involves significantly more work on packing seal. FYI the $240 gasket kit that they use on this recall includes head gaskets so they also pulled one over on you by charging for the parts. There is a significant amount of labor on that job so if they didn't charge you for the labor then most likely they didn't actually replace them which is actually a good thing.
What did they change for the parts?
The Following User Says Thank You to ermax For This Useful Post:
why? (03-08-2019)
Old 03-06-2019, 09:30 AM   #107
CT86
wannabe S2k owner
Drives: '13 Raven FR-S
*takes a Boxer engine apart for recall*
*car comes back 200 miles later completely fucked*
Customer: Why did my car die?
Toyota techs:
CT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to CT86 For This Useful Post:
caus (03-15-2019), humfrz (03-06-2019)
Old 03-06-2019, 10:05 AM   #108
Ichima
I think it was parts and a couple hours labor. I ended paying 440 for everything but that’s only because soa gave me 500 coupon. The tech did state that he saw oil leaking when they pulled the motor apart
Old 03-06-2019, 10:15 AM   #109
ermax
ermax's Avatar
Scammers.
why? (03-08-2019)
Old 03-06-2019, 10:26 AM   #110
gravitylover
Which dealership was this at? I want to make sure I never go there for service.
Old 03-06-2019, 11:27 AM   #111
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I implore everyone here to please refrain from disparaging specific dealerships or practices performed by your dealership. We're beginning to lose focus, this is a registry thread, not an experience thread. One of those has been created and I really ask for your help to keep this one clean as I suspect a lot of us will be referencing it. Should we expect them to take us seriously, let's present ourselves professionally and also show them respect.
http://www.ft86club.com/forums/showthread.php?t=133087 This seems to be a better place for briefing your concerns / inquiries about what service you were provided with.
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
humfrz (03-06-2019), ka-t_240 (03-06-2019), MuseChaser (03-06-2019), NoHaveMSG (03-06-2019)
Old 03-06-2019, 01:34 PM   #112
ermax
ermax's Avatar
Maybe create a new thread titled: "Failure After J02 Recall: Discussion Thread" and then link to it in your OP. Maybe also instruct people to link back to their post in the registry thread when starting a discussion in the discussion thread so people can easily reference their report. Maybe a mod could move the posts with discussion into this new thread. Also maybe a thread named "J02 Recall Success: Registry Thread" would be helpful. Seems more people are reporting failure than success but maybe we could get a better idea if there was a registry for that.
The Following 3 Users Say Thank You to ermax For This Useful Post:
DarkPira7e (03-06-2019), humfrz (03-06-2019), MuseChaser (03-06-2019)
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
