Old 03-01-2019, 07:04 PM   #1
lynnmichelle
lynnmichelle's Avatar
Drives: '13 FR-S Ultramarine
Valve spring recall + maint?
I'm taking my 2013 FRS in for the recall on Monday I've asked if they go ahead and do the spark plugs and they have quoted me $199 for that. Is there anything else I should have done while the engine is out? I have 75000 miles on it.
lynnmichelle is offline   Reply With Quote
Old 03-01-2019, 07:15 PM   #2
Scir16v
Drives: 240sx, 2013 frs
$199 is a bit too much, the parts are $85. Are they charging labor? they shouldn't be.
Scir16v is offline   Reply With Quote
Old 03-01-2019, 08:15 PM   #3
Gunman
Drives: 2019 Mazda Miata RF
Accessory belt.
The Following User Says Thank You to Gunman For This Useful Post:
Teseo (03-02-2019)
Old 03-01-2019, 08:16 PM   #4
lynnmichelle
Good question. I called and they said since they will not need to remove the spark plugs they are charging me full price. HA. Cancelled my appointment and going to contact another dealership.
Old 03-01-2019, 08:18 PM   #5
lynnmichelle
ooo good call on the serpentine belt
Old 03-02-2019, 12:40 AM   #6
If you have a MT and the TOB has not been replaced with the new version, you may want to have that done.
lynnmichelle (03-04-2019)
Old 03-02-2019, 12:05 PM   #7
Gunman
Read the procedure, the spark plugs will come out, in order to pressurize the cylinder, to hold the valves in place.
The Following 2 Users Say Thank You to Gunman For This Useful Post:
humfrz (03-02-2019), lynnmichelle (03-04-2019)
Old 03-04-2019, 02:37 PM   #8
lynnmichelle
Called the service manager to confirm and he said that he will speak with his service advisers so they do not give false information going forward.
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 09:44 PM
